In a blatant attempt to hijack and bump this (somewhat recent) thread with my own similar, if not identical problem, and just need a lil advice on how to proceed..
99 XJ AW4, P1698 -- I've essentially already pinpointed my issue and it's on the pinout connector to the TCM, specifically the 24, 25, 26 wires (ground, 12v constant, 12v switched, respectively) are fried from a recent boost/jump using a shop unit set to the wrong setting (broken dial :doh
. Everything was peachy before that. Now it starts, runs, everything mostly normal except its stuck in the OD gear (in drive, reverse and neutral work) - which points to the TCM and the aforementioned affected wiring..
At any rate, having checked basically everything else (cursory look at relevant fuses [both in the PDC and passenger kick panel], checked grounds and cnxns, unplugged TCM and performed/passed 'manual' mode test, speedo works, gauges good, alternator pushes 14v) without avail, I took a closer look at the TCM plug and yep sure enough those three wires look pretty crusty... granted I haven't put a multimeter to them yet but sometimes a guy gets a hunch, ya know? I've got photos, but am unsure of how to attach them.. if it works, they're at the bottom.
To get to the point, I'm wondering if anyone has any wisdom on how to fix/replace/clean just those three pins if possible for starters, or where to find a whole new plug (I'm in Alaska and junkyards are few and far between and the weather ain't exactly tropical this time of year) and if it would even be possible to realistically splice one in - it's a tricky spot to work in under the dash.
Also wondering, per forum consensus, whether I'll be doing any significant damage by driving it with the TCM unplugged and operate in 'manual' until I can get her proper again. Like I mentioned, everything was gravy before my dumbass tried jumping it on the wrong setting, and as far as I can tell my only issue is the code
I guess that's really the long and long of it, please excuse me I've been a forum member for a bit but this is my first post - I've combed through other relevant posts and was just hoping for some specific advice regarding this unique problem. If I should start a new thread for myself, I'd be happy to do so. Thanks in advance, and thanks for solving all my past issues and problems without knowing it haha!! :cheers:
https://photos.app.goo.gl/aVbaZ8ZUyeTtnw7M6
https://photos.app.goo.gl/CCo2N7PrcsUn8Ec29
