- MilkyWay Galaxy
I am about to replace the OEM heater hose and coolant bottle hose assembly on my 87 Renix XJ. The heater hoses are 5/8" ID, and I have a salvaged and cleaned up OEM steel 'T' shaped tube assembly with the all the old crimped on heater hose fittings and hose removed and plenty of 5/8' ID hose for the repair, but the bottom of the Poly bottle is 7/8" OD, or seems to need 7/8" ID hose. The OEM hose assy had a double 90 degree curved 5/8" ID to 7/8" ID hose on the assembly.
Has anyone ever found just a 5/8" ID by 7/8" ID double 90 degree curved hose that will fit this application. If so where did you get it and do you still have the part number, and if so what is it? If not what did you use to complete the 5/8" to 7/8 curved transition.
I am keeping the closed system and OEM poly bottle so please don't offer open system suggestions or metal bottle...etc conversion suggestions in this thread. I just got a headache seach nearly 100 of them for my answer!:read:
I am sure there is one out there that will work, just hoping some one else did it already and saved the part number....details.
