john mitchell
- Kentucky
91 cherokee 4 door with vent windows
my trim is getting dry and cracked
any one know a sorce for replacment?
PaulJ said:Found it for you, no extra charge.
Here the link for the post where I gave the part numbers for the seals used on my 88 XJ.
I replaced the weather stripping on my XJ this spring. It is not cheap but here are the part numbers I purchased. Make sure you verify these with the parts counter at the dealer before you order. This list may help.
Front Door - Left
55235703 Weather stripping, Run Channel - top and rear
55002337 Weather stripping, front channel attached to triangle vent frame
55235409 Weather stripping, exterior wiper
Front Door - Right
55235702 Weather stripping, Run Channel - top and rear
55235408 Weather stripping, exterior wiper
Rear Doors - Left
55235705 Weather stripping, Window frame
4728933 Left Divider bar for back seat door
55235404 Weather stripping, movable window exterior wiper
55235405 Weather stripping, fixed window exterior wiper
Rear Door - right
55235704 Weather stripping, Window frame
4728932 Right Divider bar for back seat door
Also it is cheaper to replace the divider bar than to buy the weather stripping for the rear channel of the movable channel it is also the only way to get the forward channel seal for the fixed window.
They ran anywhere from $10 to $35 for each peace. Just go into your local dealer and find out.
As far as I know, these are dealer only items. I need the lower ones, but have been unable to find a cheaper source.89LimitedXJ said:Does anyone know where to source these parts any cheaper than the STEALERSHIP?
Maz said:As far as I know, these are dealer only items. I need the lower ones, but have been unable to find a cheaper source.
_Maz
89LimitedXJ said:Is pricing on these parts different from state to state I wonder?
