Won't start when warm
XJRubicon
Minnesota
88 4.0, new TPS, new CPS, new water temp sender (cpu)
starts right up like a new jeep in the morning.
go to the store, get gas and milk, it WILL NOT start until you hold the throttle floored for about 10 seconds.... reaks like gas....
Why is it flooding out? can the fuel reg do this?! or is this leaking injectors???
TPS is adjusted correctly. air filter is new, fresh plugs, cap rotor, fuel filter.
I have been chasing this hard start problem about a month now and I am about to replace the fuel rail and the injectors with some salvage yard pieces to see if it helps...
Any help would be greatly appreaciated, thanks in advance!
:repair:
