Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
#76
Re: Balance Beads
They were clean when I put the new tires on and they were still not balancing
#77
Re: Balance Beads
You never did say what brand tires you bought???
#78
Re: Balance Beads
Nankang mudstars
#79
Re: Balance Beads
Might be part of the problem. Are you sure they're actually round?
Excerpt from the very first review I found of the tires: "Out of the 4 tires I have mounted on mine, my local tire shop was only able to balance 2 of them to ZERO (this is a tire shop that will mount and unmount a tire until is finds the best position on the wheel and will keep doing it until it's right)."
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway. -90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS. -94 ZJ: Budget boost, 31s. The wife's DD. -97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s |
#80
Re: Balance Beads
Have you checked the tires and rims for run-out?
#81
Re: Balance Beads
This coordinates with something Chickenbot said last page when asked if the issue was around before he changed wheels/tires:
"No there wasn't. It rode smooth as glass. I've put the stock wheels and tires back on just to make sure it wasn't something else and shes back to ridding smooth." So, el-cheapo tires and "new" wheels (which are seriously filthy looking with caked on matter... but "new". Maybe just "new to you"?) As we say at work: "There's your problem". You do not have a balance issue. You have a poorly-manufactured tire and/or wheel problem, sounds like to me. No amount of balance media, or balance method, will fix that. I believe RCP PHX has struck the nail firmly on the head- seems you have a runout/roundness problem. That's where I'd be focusing my efforts. Not much you can do there, to my knowledge, except get better gear.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway. -90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS. -94 ZJ: Budget boost, 31s. The wife's DD. -97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s Last edited by burntkat; March 22nd, 2018 at 08:55. |
#82
Re: Balance Beads
I have had tires trued before by a shop that handles semi truck tires, but not sure if that is still something that is offered anymore. This was back in 1985, and they take a lot of rubber off the tread to true it up. |
#83
Re: Balance Beads
Yeah, put the rear axle up on jackstands, put it in gear, and then get out and watch the tires spin. If there's much wobble at all, balancing isn't going to fix it.
DIRTY DEEDS, DONE DIRT CHEAP
...whatever doesn't kill you makes you stranger... |
#84
Re: Balance Beads
Good catch on the last two posts, gents. I wasn't aware of tire truing, and hadn't thought to test runout visually.
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
FREE BALANCE BEADS | BRIANHO13 | Vendor Give Aways | 43 | March 2nd, 2015 10:02 |
Balance beads will be back on the site tonight | BRIANHO13 | Vendor Advertisements | 6 | February 14th, 2015 16:53 |
Balance beads | BRIANHO13 | Vendor Advertisements | 0 | February 17th, 2014 06:16 |
Free balance beads | BRIANHO13 | Vendor Give Aways | 75 | November 7th, 2013 19:14 |
Balance tires with ceramic beads? | Twisted Copper | Modified Tech Discussion | 8 | February 19th, 2005 06:40 |
