lawsoncl
- North Idaho
There's been a lot of reports over the years on these boards of AW4s not taking well to the ATF+4 or other synthetics. Some have had success, others (like SlowXJ) the opposite.
Best to stick with what seems to work for vehicle.
ATF 4+ has a different friction profile. There are also tons of posts about killing Chrysler minivan transmissions when people and dealers inadvertently put dexron/mercon in them. The ATF 4+ supposedly has more slip than the dex when engaging the clutch. Using dex in a trans designed for 4+ caused clutch chatter which damaged the clutch material in the chrysler trannies. That could also explain why you see the trans run warmer on 4+.
I would have expected the TF 1000 to run warmer too, since it's much thicker than either.
