Old December 17th, 2012, 16:37
ilikefish0 ilikefish0 is offline
Fuel Pressure Regulator
I have a 96 4 cylinder with the regulator in the tank. Recently, the regulator decided to stop regulating. I replaced the assembly with a junkyard unit that seems to work, but, given that this is likely to fail, I'm trying to see if replacing just the regulator is possible.
I have disassembled the regulator housing, and the operating bit inside is stamped with a pentastar and the number 4669239 2215, which does not seem to be a valid part number. Most vendors list part number 53005801 or 53030001 as the fuel pressure regulator for my year, but the spec on this seems to be 39 psi rather than the 49 psi listed in the fsm. Any guidance on what an appropriate regulator module for this application would be? Part number 5277829 (90-95 Caravan, among others) looks like it might work and is spec'ed at 50 psi.
The photo is of the regulator and the disassembled housing.
Old December 17th, 2012, 17:49
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Re: Fuel Pressure Regulator
I wonder if your 96 is partly a 95? Is it OBD-II?
Interesting photo, they look a lot like the 87-90 Renix regulators on the fuel rails I have, but with some differences.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old December 18th, 2012, 09:09
The door sticker says August 1995, so it's an early 1996. It has OBD2, but an odd parts mix. The regulator looks like the one that other years have on the rail, but, from what I can tell, the rail regulator is lower pressure than the required 49 psi for my year. The Caravan regulator looks like its the same size and has a close enough pressure, so I'm probably going to give that a try.
Old December 18th, 2012, 10:00
Ecomike's Avatar
NAXJA# 2091
I would be real careful moving to a 49 PSI regulator! As there may have been a transition where they used a different fuel pump and lower pressure (like the label says on yours). Ask Crusier54 and some of the other experts here about the 95-96 transition (I am not an expert on it!!).
But I would be concerned about damaging the fuel pump going to 49 psi, if there was a transition!!!! And concerned the PCM might have issues with the higher pressure?
Renix and OBD-I was 30-39 psi, vacuum regulated on the rail.
Old December 18th, 2012, 12:26
Wayne Sihler's Avatar
Wayne Sihler Wayne Sihler is offline
Pressure on a 96 is 49psi +/- 2psi. Regulator is in tank and is part of the fuel pump/sender/hanger unit.
It is NOT external on the fuel rail at the motor,nor is it vacuum regulated.
Most part suppliers show the 95 external regulator as the correct part...wrong.
Wayne
Member#17
NRA Life member, AARP NovaJeepers
96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s
Old December 18th, 2012, 15:54
Ecomike's Avatar
NAXJA# 2091
Did you miss read something in prior posts? 95 model was OBD-I. This says 39 psi (link below), but it looks like the one the OP has in the tank, not on the fuel rail, but I can't see how it is plumbed from what I have to look at here. I have been told that the 96 was the year they went to 49 psi.
http://www.autozone.com/autozone/par...er=221958_0_0_
Now this is odd, they show the 1996 as 39 psi also?
This shows a new style at 49 psi in 1997?
http://www.autozone.com/autozone/par...uestid=3858337
Old December 19th, 2012, 01:35
NO. First post says 96.
ALL 96 were 49psi.Regulator is in tank.There is no return line in the fuel system.And NOT vacuum regulated
According to the FSM..."the pressure regulator is not serviced separately"
entire fuel pump module must be replaced"
For My 96 i purchased 2 complete modules.Just to get the regulator.
Wayne
Member#17
Old December 19th, 2012, 13:09
Ecomike's Avatar
NAXJA# 2091
His third post says "August 1995" build date and post #1 "the operating bit inside is stamped with a pentastar and the number 4669239 2215, which does not seem to be a valid part number. Most vendors list part number 53005801 or 53030001 as the fuel pressure regulator for my year, but the spec on this seems to be 39 psi" in his first post. Also, I see that I pulled up the 6 cyl instead of 4 cylinder in my post below too.
Old December 20th, 2012, 01:34
Regulator on one of my spares is #4669239....1496...1A,,,Mopar Pentastar
Other regulator has no number I can see...
Build date doesn,t apply as his is OBDII .And is 49 psi
Probably ,why these # are not valid is because Chrysler no longer services this part.
Wayne
Member#17
Old December 20th, 2012, 14:14
heyhar's Avatar
heyhar heyhar is offline
My '96 Country was built in 8/95, has OBDII (plug under dash), and does put out 49 PSI at the rail, which has no regulator. Mine has a bad check valve, so I let it finish priming, and it starts fine. But it will lose all fuel pressure if it sits for a while. It's been like this for two years, and seems happy, so I leave well enough alone.
Old December 20th, 2012, 18:22
Ecomike's Avatar
NAXJA# 2091
I think the so called check valve, is in fact the regulator in the tank.
Old December 20th, 2012, 20:13
heyhar's Avatar
I guess it makes sense. It's been behaving, so I haven't pursued it.Thanks for the input.
WTF fuel pressure regulator premoxj SoCal For Sale 5 October 22nd, 2012 20:01
Fuel Pressure Regulator coldforge NorthWest Chapter 2 March 19th, 2010 11:09
Fuel Pressure Regulator Inklover17 OEM Tech Discussion 4 October 11th, 2008 09:29
Fuel Pressure Regulator RyleyF OEM Tech Discussion 9 November 10th, 2005 19:20
Fuel pressure regulator? Nick OEM Tech Discussion 7 May 14th, 2005 15:08
