Hey folks, newb with a question...
The other day, I started my 2000 XJ Sport (4L) and noticed an almost gurgling sound coming from the engine. Loud enough to hear when idling, but doesn't increase in sound when driving. Also, the oil pressure gauge jumps straight to 80 and doesn't move.
After doing some research, I read the usual culprit is the oil pressure sending sensor by the oil filter. If it wasn't for the weird noise, I would have just replaced it immediately. I needed an oil change anyway, so I went ahead and changed it and noticed a slight leak coming from the oil pan gasket, so that needs tightened down or changed. After putting the new oil filter on and driving awhile, I checked underneath again and see a good bit of oil coming from the seal around the oil filter, so I bet the oil pressure really is just too high.
Further research mentions a pressure release valve on the oil pump...maybe it's stuck in a closed position? I bought a new oil pan gasket and figured I could check out the oil pump when I took off the oil pan, but after having a look, it appears to be a bit more work than I care to do, so maybe I'll just take it to the stealership for a diag and have them replace it while it's off.
Thoughts?
Thanks!
Thoughts?
Thanks!
