Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > JeepSpeed, Prerunner and Competition Tech Forum
JeepSpeed, Prerunner and Competition Tech Forum For Discussion of Modications related to Prerunning, JeepSpeed, KOH, Rock Racing, and any other speed based competitions
Old November 12th, 2020, 16:07
Blindtheft Blindtheft is offline
Bilstein 7100 Rear Mounting Issue
I'm having trouble finding out how people have handled the upper mounts in the rear. Several have mentioned using these JKS bar pin eliminator mounts:
I can't see how the remote reservoir hose doesn't bind. It's forced into the body no matter which way I try to go with it.
What am I doing wrong here?
Old November 14th, 2020, 06:19
Vince's Avatar
Vince Vince is offline
Re: Bilstein 7100 Rear Mounting Issue
I went for fixed reservoir 5150 in the rear and 7100 up front. The newer 5165 have a right angle on the pipe exit. You could put a suitable pressure rated right angle fitting on your 7100 shock tube. Or change the hoses to the banjo style that Bilstein use on the 5165, they may be available as separate parts if you can't get them made locally.
Old November 17th, 2020, 17:27
Thanks for the input/ideas!
Old August 17th, 2021, 11:37
I never did solve this issue, but here is an update. Apparently they don't fit without alternative mounting locations: https://www.naxja.org/forum/showpost...&postcount=760.
Old October 19th, 2021, 22:18
Calvin Bnvds Calvin Bnvds is offline
You can find some alternatives in stores such as 4wheelonline in case you plan on trying other products.
Rate This Thread:
Mounting 7100 Bilstein shocks in the rear. boostamante Modified Tech Discussion 9 March 19th, 2012 11:22
Bilstein 7100's TheManch Sierra Chapter For Sale 2 February 26th, 2012 12:38
Question on mounting Bilstein 7100's Explorer 1 Modified Tech Discussion 5 September 4th, 2011 20:04
Bilstein 7100 cpolish24 Modified Tech Discussion 39 July 28th, 2009 20:52
FS- Bilstein 7100's Andy in Pa. NAC Classifieds 5 June 8th, 2009 09:44
