Old February 16th, 2021, 17:23
ljobbins ljobbins is offline
Np231 no oil pump
I got ahold of a used np231 that looked like it has never been opened. When I opened it up for an sye install there was no oil pump. Did any years come without an oil pump or did the previous owner remove it? Do I need to go find a junkyard one or buy a new one or is anybody running without a pump?
Old February 16th, 2021, 17:32
RCP Phx RCP Phx is offline
Re: Np231 no oil pump
Well you can't run without the pump!
Old February 17th, 2021, 10:08
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
That strikes me as a pretty odd piece to be missing from a tcase.
Have you checked the internals against a known correct parts diagram/manual to confirm you're seeing this correctly? (no insult intended, sometimes it's good to make sure you haven't missed one of the "is it plugged in?" type answers)
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old February 17th, 2021, 17:26
Np231 no oil pump
Just a nice hole. No pump or tube or indication of anything. The areas that the pump sits in were completely filled with rtv. All the fluid looked clean and nice. The gears and chain everything are clean and no abnormal wear. The magnet didnít have anything out of the ordinary.
Old February 17th, 2021, 17:29
Np231 no oil pump
On another note, I am having a hard time finding the tube for the pump. A lot of people make or sell replacement pumps for the np231 but I am struggling to find a tube or a pump/tube combo. I can go ask the transmission shops around me but it just seems weird that the tube isnít super to find. Or maybe I just suck at google.
Old February 18th, 2021, 10:40
NAXJA Member #920
Hm. What about reaching out to NP/NV, or maybe a Jeep dealer? They're still putting these cases in new vehicles...
1984 Dodge Omni
Old February 18th, 2021, 11:13
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
NP231 are not made of unobtanium, I would stop by the junkyard and grab a good used one. The local U-Pull-It charges $99 for a t-case. If you have no idea how long it was run with no oil pump, it is suspect anyways, and I would definitely replace it.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old February 18th, 2021, 11:46
Assuming your trying to save time, but why not use your TC since you know more about it. Do you even know if it fits your XJ?
NP231 Oil pump question/issue Sluder Modified Tech Discussion 25 May 28th, 2015 14:12
WTB NP231 Oil Pump Housing SacXJguy Sierra Chapter For Sale 7 December 27th, 2012 16:17
Need pics of NP231 Oil Pump and Oil Pick Up One_Sick_XJ Modified Tech Discussion 5 July 27th, 2012 09:09
HELP!!!! 91 NP231 tranfer case swap into a 2000 automatic with NP231 Cowmanche OEM Tech Discussion 1 July 2nd, 2010 08:21
Splatter from water pump area on hood/engine bay. New pump time or new seal? pic! Plays For Jeeps OEM Tech Discussion 6 May 8th, 2008 19:15
