Old February 10th, 2021, 13:14
Unclewolverine Unclewolverine is offline
Re: What year 8.25
For the 8.25 you need the driveshaft, spring perches, and u bolts minimum. May also need the rubber brake hose. E brake should be the same I think.
Old February 10th, 2021, 19:15
az89xj az89xj is offline
Re: What year 8.25
Please explain more about the spring perch.
Thanks
Old February 10th, 2021, 19:32
Re: What year 8.25
Sorry, I got my terms mixed up, the perch is welded to the axle. I meant the plate that the u bolts go through on top of the spring. The 8.25 has a thicker tube than the 35 so the u bolts are wider so the plate they go through has the holes in a different spot. I had temporarily put a 8.25 in while I was rebuilding my limited slip in my 35. Which saying that reminded me that the ebrake cables and rubber brake line are the same, just the driveshaft, u bolts and plates were different. Good luck with the ebrake cables though. They were the hardest part of the whole thing!
Old February 10th, 2021, 19:42
jeep ride's Avatar
jeep ride jeep ride is offline
Re: What year 8.25
Originally Posted by Unclewolverine View Post
I know its not what is supposed to be done but ive never bought a new u bolt in 25 years of working on cars and never had a failure. And if a u bolt was going to break from stress my daily run would do it! You also aren't supposed to compression splice brake lines but I rekon a lot of us are guilty of that too.
We sell steel compression fittings for brake line repair they will pass a west virginia state inspection we have sold hundreds of these things over the year's we also have the brass fittings but they will not pass the state inspection t
Old February 10th, 2021, 20:52
Anak's Avatar
Anak Anak is offline
Stranger
Re: What year 8.25
Those can be a challenge.
I found I was able to make a tool to compress the three tabs on the inside of the brake backing plate by using a piece of 1/2" copper plumbing pipe. I think the copper was just a bit too large for the job, but by using a roll type tubing cutter and not reaming out the inside I was able to effectively reduce the inner diameter and achieve the goal.
Old February 11th, 2021, 08:18
Re: What year 8.25
Thank you all for all the tips.
So I need to make sure I take the bracket that is on top of the leaf springs. makes sense.
I need to come up with a special too for the Ebrake cable. Will work on that.
This is great help!!
Old February 11th, 2021, 11:38
buragozus's Avatar
buragozus buragozus is offline
Re: What year 8.25
I have never heard about it.
Old February 12th, 2021, 09:21
75SV1 75SV1 is offline
Re: What year 8.25
I've heard to use a hose clamp to compress those tabs. I've never tried it though. I usually, use a small screw driver to press them in individually or to break them off. Not fun though.
Proposal to waive one-year requirement for BOD elections this year only. SandySteve Intermountain Chapter 26 November 17th, 2013 17:46
What year is this XJ? NXJ OEM Tech Discussion 37 December 14th, 2008 09:47
OLDER YEAR ARB BUMPER FIT ON A NEWER YEAR CHEROKEE C85D4x4 Modified Tech Discussion 6 September 26th, 2006 18:32
New things i've done this year and my plans for next year ROBZ95Xj North Atlantic Chapter 3 December 29th, 2005 10:33
What year hitches fit what year XJ's wannabe Modified Tech Discussion 0 June 17th, 2004 22:03
