Old Yesterday, 10:40
BALTANAKT BALTANAKT is offline
How long do your oil pan gaskets last?
Got under the Jeep yesterday. After about 3 years since the last replacement, it's leaking. I know the 4.0 is prone to leaks, but it just go me thinking, how long should I have expected it to hold?
Old Yesterday, 14:08
Wayne Sihler's Avatar
Wayne Sihler Wayne Sihler is offline
Re: How long do your oil pan gaskets last?
Well my first one went 400,000 miles.On the other XJ,s265,000 and 150,000 respectably.
Wayne
Member#17
NRA Life member, AARP NovaJeepers
96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s
Old Yesterday, 16:13
techno1154's Avatar
techno1154 techno1154 is offline
350,000+. No leaks so far. The valve cover gasket I replaced at about 150,000. No leaks also.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old Yesterday, 18:45
Unclewolverine Unclewolverine is offline
Use a liberal amount of the "right stuff" and you have to use a chisel to get it back off!
Old Today, 05:25
cruiser54's Avatar
cruiser54 cruiser54 is offline
Are you using the Felpro one piece or the multi-piece cork gaskets?
Old Today, 08:15
denverd1 denverd1 is offline
Didn't know replacing pan gasket was a thing. Your pan bolts tight?
Old Today, 09:49
jeep ride's Avatar
jeep ride jeep ride is offline
Mileage unknown had same oil pan gasket for 10 years or so I did replace the valve cover gasket probably 8 years ago.
Old Today, 11:27
Anak's Avatar
Anak Anak is online now
Stranger
3 years and about 20K miles ago I replaced my original oil pan gasket with a Fel-pro one piece gasket. Still doing great.
Valve cover gaskets are another matter entirely. I cannot seem to get those to seal well for more than a year. I get a great seal to the valve cover, but I keep getting leaks between the head and the gasket.
Old Today, 11:51
8Mud's Avatar
8Mud 8Mud is offline
A couple of tricks, the bolt holes get a little cone-shaped on the pan, lightly hammer them flat. I found the composite gaskets smeared with high temp silicone on both sides to be the best, Felpro second best. Don't over tighten the bolts, a drop of Loc Tite will keep them from backing out. If the gasket shrinks the bolts may loosen (without the Loc Tite). If you overtighten the bolts on some gaskets you can split the gasket.
Old Today, 14:55
Thanks for posting fellas!
Using Felpro myself. I re-torqued the bolts a few months ago just for good measure. Wonder if that screwed it up! It's just a little weep at the moment at least.
I used to have an old '88 BMW 325iX. That pan did not use a gasket at all. It used this stuff called Curill instead and held up great.
Old Today, 16:38
Yeah, the right stuff was developed by gm in place of gaskets on their diesels, its freaking amazing, my xj doesnt leak a drop, I use it everywhere I can, gaskets, orings, etc.
gaskets nipper OEM Tech Discussion 20 March 16th, 2013 08:47
Gaskets? mavrick OEM Tech Discussion 3 October 4th, 2008 17:22
Gaskets... HiFiBuysTN OEM Tech Discussion 4 April 22nd, 2008 19:08
OEM gaskets XJade OEM Tech Discussion 2 December 22nd, 2004 08:02
oil pan gaskets wascobi OEM Tech Discussion 5 November 26th, 2003 23:23
