OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
#16
Re: Random inconsistent miss issues
Alright so I went and bought a noid light set to confirm what I thought was the issue but noid light is blinking as it should be so now I’m back to square one
#18
It also seems to idle lower. Around 600 rpm. Any suggestions
#19
How's the wiring look where it transitions between the engine to the firewall? It's not uncommon for the wiring to become chaffed or frayed inside, particularly if the motor mounts are bad. Often it shows up only when the engine moves during acceleration. I'd wiggle and shake that harness and see if it stumbles at idle.
#20
^^This. It is a known issue . The injector harness will chafe where it bends around the fuel rail.
.... ![]() 4shot "Babs" 97 sport 4.0 aw4 R.I.P."Buster" 86 laredo 2.8 ax5 10/85-9/17 In memory of Dave "Gonzo" Steele 1975-2008
#21
Ok so here’s what I’ve checked so far. Wiring is good from pcm to injectors. Did notice a chafed spot on the pigtail connector on the number two injector but it’s not causing an issue. I will replace it after I fix the current issue. Clean IAC and replaced TPS sensor. I noticed an improvement in driving with the new TPS but the miss and noise is still there. I’m starting to think something internal. Possibly lifters or valves.. Or I’ve heard of head gasket issues causing misfires. Will be checking fuel pressure and cylinder pressure this weekend. Maybe that will tell me something. Any tips or ideas are welcome. Thanks
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
p1391 random/intermitent miss/stumble Fix | Mediaslave | OEM Tech Discussion | 3 | March 28th, 2012 21:08 |
Random Misfiring Issues.... | ewert35 | Modified Tech Discussion | 6 | January 12th, 2012 12:02 |
inconsistent whining | kylepalmieri | OEM Tech Discussion | 4 | February 18th, 2007 15:29 |
Random Jeep starting issues | HeavyMetal | Modified Tech Discussion | 10 | November 30th, 2005 07:13 |
Inconsistent RPM? | RMORTON3 | Jeep Street and Performance | 1 | January 19th, 2005 11:20 |
