Old February 17th, 2021, 16:47
black n red's Avatar
black n red black n red is offline
Good 4.0 cam
Rebuilding my engine. Just stock nothing special. What cam would you suggest.
Old February 21st, 2021, 11:44
75SV1 75SV1 is offline
Re: Good 4.0 cam
I went with a CompCam 268 for the stroker I am building. I ordered through Bishop-Buell Racing. Russ is a Guru on strokers and the 4.0L. Also, springs become a factor with a cam. I remember $150 for the regular cam and $300 for the nitride. Basically, what you are saying you want is what I want out of my stroker. Good low to midrange for a DD and possibly towing.
Old February 21st, 2021, 19:44
CJR CJR is offline
Re: Good 4.0 cam
Here's another option for you to consider for a 4.0 XJ cam. The original cam, in my 88XJ, have dimensionally wider lobes than the narrow lobes on the newer cams. Jeep engineers designed the wider cam lobes for a reason. Likewise, there have been many threads showing the lobe thickness variations between the older and newer cams. I wanted to use the wider cam I had, so I talked to Comp Cams about regrinding my original cam. I sent them my cam for inspection and then we talked about what "grinds" could be done to my cam to get the torque vs. RPM where I wanted it to be. It worked out perfectly.
Best regards,
CJR
Old February 24th, 2021, 08:19
denverd1 denverd1 is offline
Good 4.0 cam
Stock cam is pretty good as is. Wouldn't change cam profile unless you had some reason to.
It's not like any other engine where a mild stage 1 cam really wakes up the engine. Stock is good for 95% of engines out there.
Unless you're running higher compression or some other odd setup, stay stock.
Cam Research will custom grind a cam as well
old crapy BFG ATs 33/10.50/15 good for spares or one good smoky burn out REWSTER MWC For Sale/Wanted Forum 0 April 17th, 2015 13:36
Good Mechanic? Good fabricator? (Portland area) spinaldex NorthWest Chapter 10 September 20th, 2013 22:22
Good friends+good intentions-mechanical know how=a cold drive to school 98_XJ_Classic OEM Tech Discussion 4 October 19th, 2011 20:44
Whats a good air compressor for my tires for a good deal?? 1sickxj South East Chapter 32 February 12th, 2009 18:54
need a new torch, whats a good brand/kit at a good price? orvpark Tow Rigs and Trailers 3 November 15th, 2004 03:50
