OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
Stalling issue when idiling
Hey guys, I'm relatively new here and need some feedback. I've been having some issues with my Jeep as of late. It started with it going dead one day. It acted as if the battery was completely dead. I charged it up, and got it started........though it acted like it wanted to stall. The battery was old, so I swapped it out with a new one. Anyhow, after I swapped it out it would fire right up with no problem. It would idle fine for a while, but after I start to drive it the RPM's will drop to 500 at stop signs......and on occasion it will cause it to stall. I have to put it in neutral quite often and rev up the engine to keep it from stalling. On the occasion that it does stall, it fires right back up when I restart it. Could this be the IAC going bad? I've read about cleaning it, but to be brutally honest I don't know where it's located. Is there a place where I can find a pic or any relevant info pertaning to this? Thanks for any help.
#2
Re: Stalling issue when idiling
what year and motor?
Stalling is usualkly a vaccum leak or IAC problem |
#3
Thanks. |
#4
I'm not too familiar with the new ones. if you had said 87 I'd be much more help. Wait around, someone will help you.
#5
Anyone know what sized allen wrench is used to take off the IAC?
#6
you sure it's not a torx? It's a t-15 on my 87, I think.
#7
what is an IAC?
Thread Tools | |
Display Modes | |
XJ stalling issue | LAcherokee | OEM Tech Discussion | 6 | May 2nd, 2006 19:59 |
Stalling. | Chero-King | Modified Tech Discussion | 0 | October 16th, 2005 23:30 |
Stalling | white99z | OEM Tech Discussion | 10 | October 3rd, 2005 13:22 |
overheating while idiling | bigglew | OEM Tech Discussion | 11 | May 30th, 2004 00:59 |
Stalling | bgcntry72 | OEM Tech Discussion | 5 | July 23rd, 2003 11:04 |
