Old June 28th, 2020, 15:27
outracing outracing is offline
Np242j HnT kit
Hello everyone, I just purchased a 1998 Jeep Cherokee Limited. It is a very nice vehicle with a hundred thousand miles. I would like to lift it 4 and 1/2 inches. With that size lift, I know that I will need to lengthen my drive shaft. My issue is, when I look at full SYE kits or HnT kits there seems to not be very much available for the np242j that is installed in my Cherokee. I would like to find a complete kit with everything I need to make the job is easy as possible. I would like one with the new yoke, any seals, all of the guides, drill bits, as well as the tap and bolt. Is there a company that has this available for the 242? I see lots of them available for the 231, are these basically interchangeable? Thank you for all of your help!
Old June 28th, 2020, 15:46
RCP Phx RCP Phx is offline
Re: Np242j HnT kit
There are a few full kits out there........
https://www.quadratec.com/p/tom-woods/slip-yoke-eliminator-kit-jeep-cherokee-xj-grand-cherokee-zj-wj?gclid=CjwKCAjw_-D3BRBIEiwAjVMy7BqahgIFI9E5bep_DkrMnHau1y61SiDHk20N 74eD-BuNS4KZuuar5BoCLqAQAvD_BwE
Old June 28th, 2020, 18:38
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Re: Np242j HnT kit
I don't know about the later rigs, but my 92 is sitting at around 4.5 inches, and I'm still running stock driveshafts front and rear (including the original fixed-length, slip yoke rear) without issues.
Now, I'll concede that I am running with a one-inch tcase drop - was put in back when I did the original 2 inch lift years ago to address driveline vibes, but I've never re-encountered vibes as I went from 2 inches to 3, to 4.5.
Point is, you may not need longer shafts at all.
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old June 28th, 2020, 19:49
Re: Np242j HnT kit
I was able to find that Tom Woods stuff, I was just really looking for a hack and tap kit
Old June 28th, 2020, 19:52
Re: Np242j HnT kit
I had a 98 before with an np231 transfer case. It only had a 3-inch lift, but I kept managing to break the yoke on the rear drive shaft at the axle side. I ended up installing degree shims as well which helped with the issue, but it still had some massive vibration on the highway.
Old June 28th, 2020, 21:36
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
Re: Np242j HnT kit
IRO sells everything your looking for, I run it myself.
Old June 29th, 2020, 03:50
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Np242j HnT kit
Originally Posted by outracing View Post
..... looking for a hack and tap kit
Iron Rock Off Road.
One of the guys in my local Jeep club didn't think he needed an SYE, until he did. He spent the weekend waiting for a tow truck, and calling junkyards. We spent the weekend playing in the woods.
YMMV.
Originally Posted by bimmerjeeper
People are dumbfounded when I tell them I know how to change the spark plugs on a car.
Old June 29th, 2020, 07:29
Nimrod's Avatar
Nimrod Nimrod is offline
Degenerate Jeeper
Re: Np242j HnT kit
I’m running the IRO hack and tap. I like it just fine, but if I had it to do over again I would not have spent the extra $30 on their drilling jig for reasons stated here:
Originally Posted by Nimrod View Post
I recently installed an IRO hack 'n tap yoke onto my NP242 TC. It was a straight-forward and fun little project. I haven't had a chance to test for vibrations yet because I've got to deal with a couple of unrelated issues before I can drive the Jeep. But I expect no problems.
I did make one observation about IRO's kit that I will pass on, along with a recommendation born of my experience for anyone considering this modification.
The installation instructions call for drilling a 1/4 inch pilot hole into the end of the output shaft (after cutting), followed by a 5/16 inch hole to be tapped. Drilling a pilot hole makes good sense of course, considering that the shaft is hardened steel. To ensure a straight and centered hole, IRO sells a drilling jig for $30, which I bought. Oddly though, the alignment hole in the jig is 5/16 of an inch, which makes it fairly useless for aligning the pilot hole. And once the pilot hole is drilled, the path of the 5/16 drill bit is determined and the jig becomes pointless. I overcame these issues and managed to get a perfectly centered and straight hole, but I will not credit iRO's jig with the success of the process.
My recommendation to anyone considering this modification is save $30 and do not buy the jig. It is not as helpful as it should be, in my opinion. With a little ingenuity you should be able to make a better jig yourself for a 1/4 inch pilot hole.
Here are some pictures to show off my handwork:
If you go back and read that whole thread, though, you’ll see that a couple of people disagreed with me about the jig while never actually refuting the point I made.
Here’s the thread:
https://www.naxja.org/forum/newreply...ly&p=246251088
For convenience, here’s a link to the IRO page:
https://www.ironrockoffroad.com/prod...nator-kit.html
Old June 29th, 2020, 07:56
JonnyCat63 JonnyCat63 is offline
Re: Np242j HnT kit
[QUOTE=Nimrod;246695204]Iím running the IRO hack and tap. I like it just fine, but if I had it to do over again I would not have spent the extra $30 on their drilling jig for reasons stated here:
I've used the IRO hack and tap, good product and works well on my 242.
I found the jig to be helpful. You are correct about it being 5/16", and IRO suggesting a 1/4" pilot hole. I thought the same as you did.
I started with a 5/16" bit just a little way to get my center point. Once that was established, I was able to hold the 1/4" drill pretty centered with the aid of the jig. I used a buddy's lift, though, so it was much easier to guide the drill.
I ended up selling it to another Jeeper for $20.00. Got lucky, but worked out well for me, would buy it again. YMMV.
Old June 29th, 2020, 09:31
NAXJA Member #920
Re: Np242j HnT kit
The link above jumped me into the advanced reply editor as if I was quoting Nimrod's post in the original thread. I was able to get to the thread itself, but here's a one-click way into it:
https://www.naxja.org/forum/showthre...#post246251088
1984 Dodge Omni
Old June 29th, 2020, 11:16
Nimrod's Avatar
Degenerate Jeeper
Re: Np242j HnT kit
Oops. Thanks for fixing that!
Old July 1st, 2020, 11:33
75SV1 75SV1 is offline
Re: Np242j HnT kit
I did the HnT on a '98 with the 8-1/4 rear end. I was at or still at 4.5" lift. It was actually higher, probably 6" before it settled. I had to cut to the minimum of 1-1/8" spline length. I used a front drive shaft from an Auto. There are instruction with the IRO Kit. I did have to cut some of the Yoke OD off.
I did get the drill jig. I can't remember if I used a long length center drill in the jig or not. Use a new and high quality tap. Mine was a Np 231.
Old July 3rd, 2020, 15:57
Re: Np242j HnT kit
Are the 231 and 242 HnT kits the same?
Old July 4th, 2020, 07:14
Tim_MN's Avatar
Re: Np242j HnT kit
Yes, mostly.
If the t-case has the 1996-2001 external splined output shaft the H&T is the same, 231 vs 242. If the t-case has the 1995 and older internal output shaft and requires the add-on seal housing with the SYE install you should confirm that the seal housing works with a 242.
Old July 4th, 2020, 08:25
Re: Np242j HnT kit
Originally Posted by Tim_MN View Post
Yes, mostly.
That will be most helpful! Thank you!
Anyone have an open NP242J to check something for me XJAnne Modified Tech Discussion 24 September 28th, 2019 11:58
WTB: Np242j 96+ Blktjsport SoCal For Sale 2 October 13th, 2012 19:33
NP242J questions Wallyman OEM Tech Discussion 3 April 6th, 2007 22:33
np242J to np242amg swap jeepnuts311 Modified Tech Discussion 8 November 29th, 2005 09:58
