Old June 26th, 2020, 18:20
Anak's Avatar
Anak Anak is offline
Stranger
Project Scope Creep: Ham Radio Install, Kenwood TM-V71A
I did this several years ago and never posted it up. A recent inquiry makes it relevant.
The Kenwood TM-V71A is the radio of choice in a group I wheel with. The true dual band design allows the group to have one channel for chit-chat and a separate channel for instructions from the trail boss. This means important information is not lost in the banter. This radio also happens to be a really convenient fit in an early ('96 & down) XJ. The head unit fits gracefully in the console, solving one of the challenges of where to mount such a radio in the vehicle.
Here is how I have mine set up:
The brain box of the radio is mounted under the passenger seat. I had to play around with the holes in the provided mounting bracket. My initial efforts at a low profile were too low (as you can see from the irregular hole that I made and then didn't use. If I recall correctly I spaced the bracket up through the carpet through the use of rubber isolators such as come with MSD ignition modules. I think also placed a heat shield under that part of the floorboard (underneath the vehicle, above the exhaust) figuring that part of the floor probably gets fairly warm. Here is the mounting of the brain box:
Note that I have this tucked in close to the transmission tunnel too. This required finding a wrench to install the screws for that side of the mount:
For the mic jack I purchased an RJ45 panel mount connector and a short (I think 36") cable to feed it between the brain box and the connector. I installed the connector in the rear of the center console:
Here is how it looks installed, with the mic plugged in:
The head itself is mounted in the front of the console. It takes a very short screw. Rather than cut a screw down I put a nut on a screw. This means I am assured of full engagement before I put any tension on the little brass insert in a plastic body:
And here is how it looks when buttoned up:
The mic I mounted to the driver's side of the console, just at the front of the seat:
And here is how the cable lays for the mic, making life easy for the driver when it is needed:
My antenna is a Diamond NR770HB, which is a 2m/70cm dual band which operates well without regard to ground plane. Since I use my roof for transmitter hunting (whole 'nuther subject matter) I decided to mount this antenna to my quarter panel armor:
It feeds through a bulkhead connector and an angled spacer I made to deal with the angle on the rub rails:
A roof mount would be just fine for most folks however.
I hope this provides some help to someone else looking to solve some of the same problems.
Baby it's cold outside.
Old June 27th, 2020, 13:30
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Re: Project Scope Creep: Ham Radio Install, Kenwood TM-V71A
Our 2001 Jeep doesn't have a convenient place in the console for mounting the TM-V71A, an overhead position does work, with the control box located under the driver's seat, using a separate speaker, also mounted overhead on a steel plate run between the sun visor clips.
The microphone uses modular cords, I used an HD home telephone outlet box and located the mike in a similar position.
A Larsen NMO 2m-70cm antenna is center-mounted on the roof for a good ground plane. Shown is the cap that covers the NMO socket when the antenna is not installed is shown. This location allows for a short run of coax.
The transceiver been in use for over ten years, being moved back and forth from the RV to the Jeep, and has never failed. The dual receiver sure is handy plus NOAA broadcasts can be monitored.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Finally got Scope Creep put together enough to go for a spin Anak SoCal Chapter 11 December 7th, 2018 07:09
Project Scope Creep (alfred): Lets Play with the Gas Tank Anak Modified Tech Discussion 4 February 15th, 2017 20:10
Project Scope Creep (alfred): Rear Axle Swap turned into Shackles&Relocation Brackets Anak Modified Tech Discussion 28 December 26th, 2016 16:37
Project Scope Creep : Thought I would work on antenna, did floor maintenance instead Anak OEM Tech Discussion 1 June 6th, 2016 16:01
Project Scope Creep (alfred): Educate me on R&Ring an ARB locker in a D30 Anak Modified Tech Discussion 59 February 11th, 2016 10:25
