Old June 28th, 2020, 18:33
JMO1990renix JMO1990renix is offline
Re: Rolls in gear
Old June 28th, 2020, 20:10
RCP Phx RCP Phx is offline
Re: Rolls in gear
That was kind of important info to leave out! At this point you could either swap over the SYE or look at swapping out the input gear but you will have to be aware of the gear cut and the length.
Should be a straight swap...but check
Old June 28th, 2020, 20:25
Re: Rolls in gear
BTW, get a new seal and IIRC there is a gasket to.
Old June 28th, 2020, 21:22
Re: Rolls in gear
You should be good to go, I went back and looked at my 4.1 install and it was just sealed with silicone.
Old June 29th, 2020, 15:04
techno1154's Avatar
techno1154 techno1154 is offline
Re: Rolls in gear
Glad you found the problem. You should be out having fun with the XJ this coming long weekend.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Nss replaced now it rolls in park willsmysticcobra OEM Tech Discussion 10 November 4th, 2013 23:46
Were you at the rolls(Butcher Jones)....... RCP Phx Arizona Chapter 1 September 15th, 2009 06:37
jeep rolls when in park 85xjproject OEM Tech Discussion 7 May 4th, 2008 06:47
The Short Bus Rolls tonight!! Sniggs Non-Tech / Off Topic 0 December 7th, 2006 09:35
Cherokee Rolls 800ft!!!!!!!!!!!!!! jammerjamesharmon Non-Tech / Off Topic 19 August 18th, 2004 16:07
