Gear ratio upgrade with existing locker
Atlas95XJ
Phoenix, AZ
My 95 xj has an ARB air locker on the front Dana 30. It's geared in 3.55 and I want to go up to 4.10 because I have not beem getting alot of power ever since I went from stock tires to 31s. Will I have to buy a new locker or do I have other options? TIA
Seems I remember seeing somewhere you could get gears that had a different thickness that would allow you to go with higher ratios on the low ratio carriers. It would be worth some looking.
Not for the Dana 30!
