OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
OEM Overhead temp sender?
I was just wondering if anyone knows where the probe for the Temperature in the overhead console is located? Last night it was about 90ish out and it was reading 128* The compas works fine but not the temp.
#2
Re: OEM Overhead temp sender?
Right behind the front bumper, straight down from the middle header panel support.
#3
i was thinking on moving it near the vaccum bottle on the passenger side, twords the fender. it would pickup less from the radiator there...
#7
I'm Going to move it as far away from the Rad as I can get it!
#8
If you want, crim and install wire so you can run it to the rear of the vehicle, on the driver's side (not to pick up exhaust heat, of course!)
Or I suppose you could mount it inside the bumper, towards one of the sides. I'd try that first before making a vehicle length extension harness ![]() |
#9
![]() Jim www.yuccaman.com |
#10
yeah, it is kinda fun to see how high it will climb while wating for your Big Mac... we had a '00 WJ grand cherokee and it's temp sensor was on the drivers side behind the grill, and it never seemed to pick up any "extra" heat, what about an upgrade to a newer chrysler temp sensor???
#11
That may be a good idea to go with a new temp sender, maybe it is a little more accurate now. My problem is that even when drivin down the road at 40mph the gauge still seems to be off.
Thread Tools | |
Display Modes | |
were is the coolant temp sender | jp904x4 | OEM Tech Discussion | 7 | December 13th, 2006 18:00 |
Which Temp sender to change?? | mjma | OEM Tech Discussion | 2 | February 11th, 2006 21:23 |
coolent temp sender | XJ97 | OEM Tech Discussion | 8 | October 11th, 2005 21:35 |
where to get Temp. Sender online? | BrettM | OEM Tech Discussion | 3 | April 25th, 2004 08:03 |
Temp sender/ engine coolant sender, same thing? | Angus | OEM Tech Discussion | 8 | March 29th, 2004 11:59 |
