Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
cluster swap Q
OK i have a dummy cluster and want to switch it to one with a tach. i have been reading alot up on this. SO HERES MY Q my cluster is a lil diff to the all lights dummy cluster. I have a tach for oil presure and a tach for my temp and battry ect.. the thing i do have is THAT BIG AS@ STUPID GAS GUAGE. would i need to go tought the proscess of changing the oil and temp sensors if i dont have the dummy lights... once again the only dummy thing on my gauge is the huge freakin gas gauge
#2
Re: cluster swap Q
NO, if you already have the two guages and they are working you already have the right sensors.
#3
Re: cluster swap Q
Just find a cluster with a tach. Since you have all gauges, you do not need to swap the temp and oil senders.
The tach cluster is plug and play, no extra wiring needed. Depending on year, 84-86 plug and play, and 87-90 are plug and play. |
#4
Re: cluster swap Q
I did this upgrade on my 89 because I had that stupid gas gauge too and no tack. It was simple remove old and put in new and your done. I would try to find the one your looking for out of the same year vehicle so you dont have any problems with it but its well worth it. I also changed from a ugly blue highlight on the gauges to a orangish/red color. Looks alot better.
#5
Re: cluster swap Q
That's what i thought gang THANKS! gotta love
#6
Re: cluster swap Q
He's a bonifide member, not a user, lol.
#7
Re: cluster swap Q
Thread Tools | |
Display Modes | |
90 to 89 Cluster swap | OverTheHillsATTW | OEM Tech Discussion | 2 | March 17th, 2008 16:17 |
Cluster swap | gbarkan | Wanted: Private Party Only | 4 | April 27th, 2005 06:33 |
cluster swap | Kejtar | Modified Tech Discussion | 16 | July 25th, 2004 21:36 |
Yet another cluster swap-out question | crystalship1 | Modified Tech Discussion | 6 | July 4th, 2004 17:22 |
Gauge cluster swap ? | CW | Modified Tech Discussion | 2 | June 15th, 2003 17:20 |
