Old February 22nd, 2006, 12:11
SourApple SourApple is offline
rock rail tech
hey guys, if i make some rock rails what will happen if I leave out the pinch seam part? im not going to be using the rails to there full potential either. just a thought , thanks
Old February 22nd, 2006, 12:36
gcurtis gcurtis is offline
Shirley Temple was a nug.
Re: rock rail tech
http://www.kevinsoffroad.com/rocksliderz.html
Old February 22nd, 2006, 12:48
Kejtar's Avatar
Kejtar Kejtar is offline
PostMaster General
Re: rock rail tech
How can you be sure that you're not going to be using them to their full potential? How are you going to be using them? Anyways, why not time them into the pinch seam and get it over with????
Old February 22nd, 2006, 18:21
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: rock rail tech
If you leave out the pinch seam tie in, the rock rails will pivot on the frame mounting points and drive the legs up into your rocker panels. If you are 100% street use I guess you could............
Originally Posted by bimmerjeeper
People are dumbfounded when I tell them I know how to change the spark plugs on a car.
Old February 23rd, 2006, 18:51
Pete M's Avatar
Pete M Pete M is offline
Re: rock rail tech
That's precisely why I put the bars through the frame and welded them to plates on both sides. My MJ is missing a good portion of the rockers so using the pinch seam was not an option.
Jeep on!
--Pete
Old February 24th, 2006, 06:31
collegeoffroad's Avatar
collegeoffroad collegeoffroad is offline
Re: rock rail tech
dang....props to you Pete M- those are some sweet looking rails! I don't know much about them on the whole, but is there any chance that you might do some frame damage by really coming down on the rails? I'd imagine the frame would be strong enough, but I've never seen a design like yours before. Congrats on a really unique design!
Old February 24th, 2006, 06:55
Pete M's Avatar
Re: rock rail tech
Thanks! I've taken every opportunity to fall on them and no damage or deflection to date. I did think about that though and went with 3 runners instead of 2 and used a plate to spread out the load. I was far more worried about coming down hard and tweaking the body if I had them attached to the pinch seam (if I had any pinch seam left) or rust attacking my body if it was still rust-free. But Comanche uni-frame rails are stronger than XJ uni-frame rails so maybe more research needs to be done into XJs. I guess what I'd say about XJs is, if you're worried about coming down hard and hurting the frame, your Jeep is a prime candidate for sleeving the frame with angle iron anyway so the system would turn out to be very VERY strong in the end and still free-floating from the body.
There should be more photos at picturetrail.com/petermontie in the "armor" folder.
Jeep on!
--Pete
ComancheClub.com
is this rail bent? METAL MONKEY OEM Tech Discussion 1 October 5th, 2004 17:54
Yet another Rock Rail Ques. csudman Modified Tech Discussion 9 October 6th, 2003 18:07
Rock Rail Install 6/1 MJR SoCal Chapter 5 May 30th, 2003 16:09
Bent Frame Rail.... Help! Ted Z OEM Tech Discussion 18 May 21st, 2003 20:58
(NV) Draft EIS for the Black Rock Desert-High Rock Canyon Emigrant Trails... Ed A. Stevens Land Use Forum 1 March 20th, 2003 09:56
