Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Midwest Chapter
Midwest Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Thread Tools Rating: Thread Rating: 221 votes, 4.98 average. Display Modes
  #67321
Old June 24th, 2014, 12:57
macgyvr's Avatar
macgyvr macgyvr is offline
NAXJA Member #120
Important
mac 'four generations' gyvr
MWC President / President
It's always a good time to join or renew your membership!
My idea of a perfect vacation is a road trip through beautiful country. To make it really fun, all that's needed is a modified vehicle, a few close friends, and some serious off-roading. Cole Quinnell - Editor, 4WOR, Dec 99
Old June 24th, 2014, 13:20
*89Laredo* *89Laredo* is offline
Re: Important
Cleaning the haymow in 85* heat sucks.
Old June 24th, 2014, 13:42
terrehautian terrehautian is offline
Re: Important
Originally Posted by 1989TwoDoor View Post
Large tornado, maybe a EF4 just went through Indy and the Suburbs. Lots of people in its path....Crap...
I don't know if it was that large, doesn't sound like major damage at this point from what I have read about. After being in an area a few times were EF4/5 tornadoes went though, that would flatten everything.
Old June 24th, 2014, 13:49
87manche's Avatar
87manche 87manche is offline
Re: Important
Originally Posted by DoWorkXJ View Post
4.0's don't need oil pressure. Just drive it.
this.
josh drove one with 0 oil pressure for a month back and forth to work.
might as well be splash lube.
Old June 24th, 2014, 14:59
DoWorkXJ DoWorkXJ is offline
Re: Important
uploadfromtaptalk1403647173041.jpg crawl prep
Old June 24th, 2014, 15:09
RedHeep's Avatar
RedHeep RedHeep is offline
NAXJA #1499
Re: Important
Cam bearings, rod bearings, main bearings and rings all in one mud puddle.
I drove it for 2 months 40 miles round trip with the needle on the peg. The 4.0 that Dan has was the replacement I ordered from a JY with 48k miles on it before I knew peeps on .
It doesn't need fixing, it needs thicker oil.
Old June 24th, 2014, 15:29
Jeepguy91's Avatar
Jeepguy91 Jeepguy91 is offline
NAXJA Forum Addict
Re: Important
How much lift would I get out of making a bastard leaf pack out of 2 sets of xj springs. Everything I have found so far is using s10 springs. Needing to beef up the rear of the jeep a little bit. Maybe even lift it an inch
National VP/ MWC Recorder
Ben-2000 XJ with add ons
Old June 24th, 2014, 15:32
poorboy87 poorboy87 is offline
Re: Important
Mines been on Rotella since Ive been driving it. The rear main seal went out on me and puked oil at about 3 quarts per 15 miles. I stabbed a high volumn pump in it and a set of rod bearings for good measure. It used to carry 60 lbs cold and then about 25 hot idle and would build when it was revved. Now its about 40lbs cold and fluctuates between 20 and 40 hot and doesnt move.
It hates its life in winter time. Pecks on the top end for 10 minutes before it starts flowing up there. Its getting a block heater this fall.
MKR5150 MKR5150 is offline
ZFG
Re: Important
Just over the thickness on the extra leafs you add, depending on how worn out they are.
Try it.
Old June 24th, 2014, 16:52
donthelegend donthelegend is offline
Re: Re: Important
I got about 1.5"- 2" out of two well worn packs using all but the overload and one other leaf, I don't remember which other leaf I left out though. Thinking it was the third leaf.
Old June 24th, 2014, 17:15
w_howey's Avatar
w_howey w_howey is offline
Re: Important
anyone know anything about gas grills?
The knobs on mine are getting really hard to turn and one has decided to only turn half way now.
AMSOIL Independent Dealer
Old June 24th, 2014, 17:18
BRIANHO13's Avatar
BRIANHO13 BRIANHO13 is offline
<- Yum Chocolate
Important
Try having someone else turn them, maybe you are getting weak.
Really, I have nothing to add
Old June 24th, 2014, 17:31
lesslimited's Avatar
lesslimited lesslimited is offline
Official MWC Brewmeister
Re: Important
I got about 1.5-2" just adding average wear main leafs with the eyes cut off, on my 94. They've held up great for over 5 years now, loading it down with hundreds of pounds of tools and supplies.
And the 213k motor has 40psi at hot idle, 60+ cruising, on whatever oil Menards has on sale.
John
99 XJ Limited 4.5", RC, RE, JKS, JCR, ACOS, HDORE, 4.56s, Detroits F/R, 33s 98 XJ Limited, wife's daily driver, 96 XJ Sport work truck /daily driver, 06 E350 PSD work truck/tow rig
WWFSMD
Old June 24th, 2014, 17:43
Jeepguy91's Avatar
NAXJA Forum Addict
Re: Important
Do you think it would still give an inch or 2 of lift even with the add a leaf I have in there now? I know I should just buy new leafs but it won't be in the cards for a while and just trying to help out the rear suspension a little bit.
Old June 24th, 2014, 17:45
Fore Wheeler's Avatar
Fore Wheeler Fore Wheeler is offline
Past MWC President
Re: Re: Important
throw it away and grill with charcoal. I don't have any issues with my knobs.
member #285
My build thread: Out of Misery II
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
Rate This Thread:
IMPORTANT chelms27 Midwest Chapter 1 October 3rd, 2006 01:43
Most Important Rocketman Modified Tech Discussion 15 March 25th, 2005 19:23
how important is it? littlexj1 OEM Tech Discussion 2 March 22nd, 2005 08:38
