Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > JeepSpeed, Prerunner and Competition Tech Forum
JeepSpeed, Prerunner and Competition Tech Forum For Discussion of Modications related to Prerunning, JeepSpeed, KOH, Rock Racing, and any other speed based competitions
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
  #256
Old March 22nd, 2009, 07:11
TNT's Avatar
TNT TNT is offline
Seasoned Veteran
Re: Pre-runner type suspension stuff
Originally Posted by Jimbo_1321 View Post
you were the one talking about moving the battery and taking that dip in the fender "out" right?
btw where have you been for the last few months?
The dip is done and the wheelwell is huge due to other work I've done.
I also removed the spring tower and will probably be going with some 14" coilovers if I can afford them. If not I'll run some leaf springs I have until I can afford it.
I made the front dip disappear and now the wheelwheel ends just under the headlight. I removed the turn signal and will put a new light into the raised bumper ends. The side marker will be shorted about 2"
and reused.
The back is stretched back about 7" so it ends below the a-piller. I have one spot to weld in and some cleanup left to do.
Pictures will come soon hopefully. A friend is going to help me out.
I had another back fusion done a couple of months ago. I have to wear a back brace for about 2 more months.
Old March 22nd, 2009, 07:56
Jimbo_1321's Avatar
Jimbo_1321 Jimbo_1321 is offline
I'd love to see some pics, I remember you talking about it and wanting to do it. but not wanting to be the guinea pig
and I'd definitely save a few months and do coilovers instead of skimp for a bit and do leaves.
pics would be awesome!
bummer about the back man, I was supposed to have surgery about a year or so ago, but for some reason my back problems suddenly disappeared...
I'm sure that'll come back to bite me someday though...
Old March 25th, 2009, 08:14
Goatman's Avatar
Goatman Goatman is offline
Originally Posted by Mosephus View Post
Old thread I know, but I figured My question could be answered here.
Is the anything wrong with mounting a reservoir shock's reservoir upside down(shrader valve pointed up) to the shock body?
Just wondering if it could operate properly that way. The shocks I just got bought hose is really too long to mount it the correct way.
Just to add to the answer you already got, the oil and air in the reservoir is seperated by a dividing piston, so it makes no difference how the reservoir is mounted.
That's a long hose........
TEAM/PETTY CASHRacing........2013 Ultra4 Stock Class National Champions
Check out the TEAM Facebook page for the full story of our 2013 winning season: https://www.facebook.com/Team
Thanks to , Falken Tires, Bishop-Buehl Racing Engines, Ten Factory Axles, Brown Dog, Hooker Harness, BILSTEIN, Raceline Wheels, WARN, G&G Auto Repair/Off Road, Yukon Gear and Axle, Full Traction, Cal, Russ, James, and many, many others.
Old March 25th, 2009, 09:27
Mosephus's Avatar
Mosephus Mosephus is offline
Thanks Richard.
Old February 16th, 2012, 20:15
karstic's Avatar
karstic karstic is offline
THis should be a sticky
Old February 16th, 2012, 21:33
cheapcherokee93 cheapcherokee93 is offline
<----boat-manche
holy crap thats a ton of reading.
cliff notes???
Old February 16th, 2012, 23:03
GrimmJeeper's Avatar
GrimmJeeper GrimmJeeper is offline
Originally Posted by cheapcherokee93 View Post
cliff notes???
save your money up and do it right the first time
Old February 19th, 2012, 09:37
Goatman's Avatar
Funny that this thread is still floating around, after what, 8 years? Look where we've come.
Old February 19th, 2012, 21:50
slappomatt slappomatt is offline
let me qoute this one more time for effect. Ask anyone who is into go fast and has rebuilt their entire rig and wheels and tires $$$$$$$$$$$$ 4 times to get where they are and they will all say the same thing. save your cash and figure out where you want to end up and go there first.
Old August 7th, 2012, 00:53
KRAKER KRAKER is offline
I ended up thinking the same thing.
Old August 8th, 2012, 17:00
Darky's Avatar
Darky Darky is offline
Ask and you shall receive...
Old March 22nd, 2014, 08:07
Andhi Satria Andhi Satria is offline
Cool Re: Pre-runner type suspension stuff
Front Independent Cherokee 97 with 2JZ Turbo.
This is the 1st Jeep Cherokee (1997) in Indonesia, utilizing DOUBLE WISHBONE Front A-ARM dan 2JZ Engine for Offroad Racing in Jakarta, INDONESIA.
Old March 22nd, 2014, 09:26
XJEEPER's Avatar
XJEEPER XJEEPER is offline
NAXJA Member # 13
More details am photos of this IFS setup please!
Speak the Truth-Question with Boldness
Old March 22nd, 2014, 16:05
For detail Pic :
http://www.naxja.org/forum/showthrea...#post246078304
Old May 20th, 2020, 02:45
frijolee frijolee is offline
Bumping an old thread because I've been reading quite a bit and not finding what I'm looking for (but this is as close as I've come)
Summary of notes to date (having just read this entire thread).
-275/78 front and 255/70 rear is a common recommendation for damping on all around rigs that both crawl and like to go fast on occasion. Some guys like 360/80 front but this is getting damn firm. Bilsteinís guide can recommend either. https://www.my4by.com/bilstein-valving-guide
-Best practice is to flex test before committing to shock lengthsÖ That said, at about 6Ē lift (reasonable for going faster) 12Ē travel fronts and 10Ē travel rears are common
-Many of the better shocks will require converting to a 1/2Ē eye style top mount. TandJ makes a nice conversion. JKS has an OK one but they sometimes loosen up so TandJ (or custom fab) seems like best practice.
-Lower front shock mount relocation is common too: typically a drop moving the lower mount point outboard of the lower control arm pockets
-7100 Short Bodies seem like the "go to" at high end of the low end. I donít much like how the reservoir hose on the 7100s exit the shock (rigid, pointing up and out). The 5160s (direct fit) or 5165 seems like a better option if one prefers to have the reservoir mounted to the shock body. Compare the orientation of the hoses.
7100
5165
-I canít tell you why sometimes the 7100s have a blue rubber hose and sometime a SS hose.
-Thereís a slight challenge that the Bilstein catalog (https://cart.bilsteinus.com/Portals/...og2020_WEB.pdf) doesnít publish either lengths or damping for their direct fit stuff. Eshocks.com appears to be gone. So if anyone knows of a searchable resource that might be handy.
-It appears that the 5165s can be custom valved but they only come with 255/70 and 360/80 by default. Unfortunately, that seems to skip over the more common valving recommendation at 275/78. More notes on valving 7100s here: https://www.naxja.org/forum/showthread.php?t=994685
-Front spring rates in the 230 to 240 lbs/in are popular (Skyjacker, BDS, maybe Deaver). In the rear, everyone just calls Deaver.
Questions
-Are the stem style shock tops inherently limiting? Iíve blow up several sets of shock bushings which is annoying but not that expensive all things considered.
-Several folks allude to failures of the rear shock upper mounting within the thread. Anyone have pictures of where how it fails? My rig sees quite a bit of daily driving as well so I need to keep the shocks outside (not cutting body for towers) but Iíd love to find a way to reinforce the original mount.
-Iím running Bilstein 5100s in the back of my rig now and the bushings are cracked. Is this a systemic issue with Bilsteins?
-Stupid question, but do 5100s have a top and bottom? Iíve seen them installed both ways.
-If someone were willing to spend some coin beyond 7100 SBs, what's the next step up? I can find some guys talking about 2.5 class shocks but little info on more specific recommendations. Iím not sure I really need it but Iíd like to know. I've been running some longer trail rides and I keep blowing up my top shock bushings so I'm thinking it time to go a notch more serious, the question is how serious?
2.5 class shocks seems like they start around $400 per. One weird bit is that it seems like King or Fox smooth body 2.5s come in notably longer body lengths for a given travel. Compare:
---King 10" smooth body (KRS-PR2510-SSPB) is 18.3" collapsed length
---Bilstein 7100 SB (AK7110SB) is 14.3" collapsed length
-King and Fox seems to rate their damping based on shim stacks. IE ď10/12Ē damping would be a tapering shim stack with 0.010Ē shims on rebound and 0.012Ē shims on compression. (https://www.crawlpedia.com/shock_tuning.htm). Bilsteinís ratings are Newtons of resistance 255 = 2550 compression but I donít know at what speed. Anyone know how to make comparisons between the two rating styles?
Anyways, good resources like this thread are why I love the forums, so I'm hoping some folks can help me out (while in turn I hope the clarifications help others.)
Regards,
-Joel
Rate This Thread:
pre runner or regular brush gaurd jimmy forbes Modified Tech Discussion 4 February 21st, 2006 13:45
A few questions: suspension, vibe Q's, year specific stuff. nitrogt101 Modified Tech Discussion 0 February 20th, 2004 17:35
stock suspension stuff and other extras BanditXJ For Sale: Private Party Only. XJ ITEMS ONLY 9 January 4th, 2004 11:31
What Tires Will Stuff BrianJr Modified Tech Discussion 9 December 9th, 2003 10:58
XJ Drivetrain, suspension stuff jlake1 For Sale: Private Party Only. XJ ITEMS ONLY 16 October 1st, 2003 18:51
