Old May 1st, 2020, 09:16
SouthernAeroXJ SouthernAeroXJ is offline
97 P0700
1997, AW4. Hey guys, Iím about to loose my mind troubleshooting this problem. A couple weeks ago my TC stopped locking in overdrive. Threw a P0700 code with NO other codes. Did some troubleshooting and found the TCC solenoid was bad. I went ahead and replaced all 3 solenoids, filter, and fresh fluid on Wednesday. After replacing everything I drove it nearly an hour Wednesday evening with absolutely no problems! TC locked up, shifted great, and no more P0700. I was very happy. Yesterday morning I hopped in it to go to work. As soon as I put it in gear BAM P0700 came back and it lost 1-2. Starts out in 3rd or 4th. Iím having to manually shift now with no TC lockup in OD. So far fluid is good, NSS is good, brake switch is good, TPS is good. Only thing I havenít checked is the TCM/TCU. Itís pissing me off it performed perfect after replacing everything then the next day itís even worse than it was before. Is it possible the 1-2 shift solenoid which is brand new is now bad?! I know the 97 has different wiring than other years and I canít seem to find a good diagram thatís not 96 or 98. Someone help. Please.
Old May 1st, 2020, 11:57
RCP Phx RCP Phx is offline
Re: 97 P0700
You would need to be able to see the actual code thrown by the TCU. P0700 just states that the TCU is sending a message on a malfunction in the trans.
Old May 1st, 2020, 11:59
97 P0700
I took it to a local mech and hooked his big Marco scanner to it. P0700 is the only code. There are no specific TCM codes thrown.
Old May 1st, 2020, 12:17
Re: 97 P0700
A take it you meant Matco, but not all scanners can read sub-codes.
Old May 1st, 2020, 12:24
97 P0700
Yes I meant Matco. Damn autocorrect. This one does 🤷🏻*♂️
Old May 1st, 2020, 19:44
Re: 97 P0700
Evidently it doesn't! You need to see the code that set off the CEL.
Old May 7th, 2020, 20:04
lawsoncl lawsoncl is offline
Re: 97 P0700
Check the fuse and that the connector at the trans computer are still attached first. Your symptoms sound like you don't have power to the trans computer.
p0700 and P0705 with new NSS maybe2fast OEM Tech Discussion 8 March 21st, 2016 16:13
P0122 and P0700 Ghost OEM Tech Discussion 12 January 14th, 2015 13:03
P0700 code Pz10420 OEM Tech Discussion 9 April 24th, 2013 10:05
P0700, P0705 97 XJ Fred Colorado Chapter 5 July 12th, 2011 19:36
CEL: P0700 Mullet Man OEM Tech Discussion 6 March 7th, 2008 09:07
