Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > JeepSpeed, Prerunner and Competition Tech Forum
JeepSpeed, Prerunner and Competition Tech Forum For Discussion of Modications related to Prerunning, JeepSpeed, KOH, Rock Racing, and any other speed based competitions
Old October 3rd, 2018, 18:50
Tankerblade Tankerblade is offline
Beams!
So looking at starting a jeepspeed wannabe desert trashcan. And have came across a set of beams from supposedly a ranger and been extended.
What are the average lengths jeepspeed guys are using??
The beams I'm looking at seem to be LONG. 57" from heim to hub.
And since everyone loves pics here's a pic of the beams
Old October 3rd, 2018, 18:59
Beams!
I should mention I feel like they'd be long the jeep. At 57" it puts the hub mounting about 3-4+" outside past the body. Which to me would make shock mounting a bit difficult.
But looking for input
Old October 11th, 2018, 12:47
LLLux31 LLLux31 is offline
Re: Beams!
All the Jeepspeed guys are running a 2wd beam or 4 links usually from full-traction. I didn't see one at the Mint 400 this year running a beam or ttb setup. Also those would be against the rules about extending the wheelbase in most classes.
Old October 12th, 2018, 15:13
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Re: Beams!
start here
https://naxja.org/forum/showthread.php?t=1088116
Rate This Thread:
Low beams on, flip to High beams, lose both and cluster lights fallacist Modified Tech Discussion 3 July 13th, 2015 13:05
Kolak Harness on '99 XJ - High Beams Stuck on w/ Low Beams notamos Modified Tech Discussion 10 August 18th, 2012 08:53
No Low Beams on 89 Maigus OEM Tech Discussion 5 September 25th, 2008 11:35
Is there a way to keep the low beams (and possibly fogs) on with the high beams? nosajwp OEM Tech Discussion 8 March 9th, 2005 23:04
no low beams for me! tom from boston OEM Tech Discussion 6 April 7th, 2003 19:29
