Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > JeepSpeed, Prerunner and Competition Tech Forum
JeepSpeed, Prerunner and Competition Tech Forum For Discussion of Modications related to Prerunning, JeepSpeed, KOH, Rock Racing, and any other speed based competitions
  #16
Old May 9th, 2014, 03:36
XJLI XJLI is offline
Re: Light bar mounting
Originally Posted by Marcelo73 View Post
that would work, its just $$$. i mounted my 42" to some tabs on my exo cage.
Old May 9th, 2014, 19:41
NW-ZJ-SCOTT's Avatar
NW-ZJ-SCOTT NW-ZJ-SCOTT is offline
X2
ZJ, Atlas 4 speed
MJ, 4.0HO Shortbed
Old May 11th, 2014, 18:25
goodwilljeeper's Avatar
goodwilljeeper goodwilljeeper is offline
i saw that but i have a sun roof from the dealer and they cut the roof rack mounts to far back so it would have to be a custom one.
i think I'm going to try and make a mount that uses the roof gutter clips like that second one but follows the roof line somehow so that way its sleek, but I'm not sure if i can make gutter clips by just bending metal.
and i wish i could build my cage now
Old May 12th, 2014, 15:39
Marcelo73 Marcelo73 is offline
Jcr sells roof mounts. Maybe you could use it (or the idea)
Old May 12th, 2014, 20:54
Re: Re: Light bar mounting
Huh, I will look that up
Old May 12th, 2014, 21:18
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
He might be talking about the gutter mounts for a roof rack. But yes, those would be easy to build off of. If you and Kevin cannot find another way to do it.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old May 12th, 2014, 21:34
Yeah I saw those. Might be a possablilty
Old May 13th, 2014, 10:41
NorCalChris NorCalChris is offline
Dirtbound offroad makes one that might work on your 41. Check it out. Call max and give him your actual width from end to end. It might work
Old May 13th, 2014, 21:54
This:
http://www.jcroffroad.com/product/XJ/RCKMNTS.html
But cost 60 (50+10s&h).
Old June 1st, 2014, 13:20
So I ended up just mounting it to the bumper for now. Ignore the angry eyes. They're a joke
Old June 1st, 2014, 14:03
Light bar mounting
That is the last place id want to keep that mounted, I'd rather not use a lightbar as a bumper
Old June 1st, 2014, 14:05
Right. Shouldn't be mounted there for long. Went on a few trips already w it like slickrock and haven't hit it yet. Will just stay carefully for now
Old June 1st, 2014, 23:28
GordoSmasho's Avatar
GordoSmasho GordoSmasho is offline
Light bar mounting
I'm thinking of fabbing a bracket to mount my future light bar/bars above the cowl area. Just above the wipers. Thought that might be a cool place to put it and glare off the hood(I have a white jeep) should not be an issue because the light itself would be in the sight line of the reflection off the hood.
Old June 1st, 2014, 23:39
DesertRunner DesertRunner is offline
i whipped this up at work (dirtbound offroad) the other day
its 44.5" plate to plate should be able to mount your light bar off that. you would have to weld on some tabs or call and talk to max with measurements and i may be able to weld them on for ya.
Old June 2nd, 2014, 16:48
Ohhh. I love that!!! I will definitely be in contact. Thank you
Rate This Thread:
Fog light relay mounting? gw204 OEM Tech Discussion 6 January 16th, 2013 12:32
Light Switch Mounting??? dark92xj Colorado Chapter 2 January 18th, 2011 22:20
light-mounting options? whatevah OEM Tech Discussion 5 January 3rd, 2006 21:48
auxilary light mounting atticus032 Modified Tech Discussion 5 February 2nd, 2005 21:28
FS: Yakima Light mounting Bracket ruggedjeep For Sale: Private Party Only. XJ ITEMS ONLY 9 July 20th, 2004 00:15
