Old January 7th, 2013, 14:23
Cottontail's Avatar
Cottontail Cottontail is offline
Three-De Off-Road
Re: For those wanting a complete WJ knuckle swap parts list
Originally Posted by 2001XJ View Post
Well, if you don't want to replace NOTHING EXCEPT THE KNUCKLES, you can get it down to (u have to have ball joints so you might as well do all four):
2003 Jeep Grand Cherokee Powerstop slotted rotors
Mopar Factory Jeep Grand Cherokee Akebono Caliper Kit 94-99
Grand Cherokee (WJ) outer steering knuckles 94-99
Grand Cherokee (WJ) caliper brackets 94-99
WJ knuckle flange spacer
Dana 30 Super, Ball Joint Kit (upper & lower)
*Timken Wheel Hub Assembly (if you don't have a 2000/2001XJ)
otherwise its best to replace unit bearings and u-joints while you are doing it.
Thanks. First I am in the 2nd, 3rd, and 4th you meant 99-04 for the WJ years. Just making that correction for anyone else that reads this that might get confused.
I have a 2001 XJ, so it sounds like all I need is the knuckle, the caliper and brackets, and flange spacer from the junkyard.
The rotor, pads and ball joints from the parts store.
I've read that since I have the 2001 XJ there is nothing I need to do with the master cylindar. Should be ample for the WJ brakes.
Dirk DeYoung--Member #176
You'll never leave Harlan alive.
1996 ZJ (200GRND)...2001 XJ (TRALRIG)...2006 XK (TOW RIG)
Old January 8th, 2013, 15:10
Serious Offroad Serious Offroad is offline
I've got a great set of Ball Joints for those doing this swap.
http://www.seriousoffroadproducts.co...K-And-99-04-WJ
Old January 8th, 2013, 16:00
XJ jay XJ jay is offline
That's a grate price Frank, the mood replacements for my XJ ran me $320 through one of my jobber parts suppliers.
Moog I mean. Damn iPhone.
Old January 8th, 2013, 16:03
Thanks for noticing.
Old January 8th, 2013, 19:28
blenny blenny is offline
RRC President
What are people using the ruffstuff offset tre doing for wheels, my 15x8 d Windows 4in bs won't clear the tre when turning. I just threw in some spacers
Old January 8th, 2013, 19:47
Vanimal Vanimal is offline
i ground a bit off of the tie rod ends to clear my wheels. seemed to work. but i killed those TRE's in a couple months so i switched to heims.
Old January 9th, 2013, 04:16
2001XJ's Avatar
2001XJ 2001XJ is offline
If you use steelies you can get away with grinding down the TRE and BARELY getting it to work. Otherwise if you use aluminum you have to go up to 17" due to thickness of the material. I had to use 17s with a 5x5.5 spacer adapter because I could not find 17s in 4" backspacing with a 5x4.5 BP. The 17s I went with are 5.0BS then with the spacer being 1.25" it make the total BS 3.75 which works perfect.
Here are the rims I went with:
Old January 10th, 2013, 17:47
chvymtl3 chvymtl3 is offline
Will this swap work with the old Warn Hub Coversion kit?
Old January 10th, 2013, 18:42
1990JEEPXJ's Avatar
1990JEEPXJ 1990JEEPXJ is offline
the knuckle/hub flange spacer is not a junkyard item. JKS sells them
Old January 14th, 2013, 02:28
Devilfrog Devilfrog is offline
for the TRE's ... use the Synergy double adjuster and use common off the shelf 1 ton TRE's and bend the Tie rod tube as needed. Mine has a slight bend at each end with the adjuster on the driverside. easy adjustments and lots of clearance. 15x8 steelies fit with lots of room, but likely have to go to 16" wheels in aluminum.
Old January 14th, 2013, 02:44
99-04 Jeep Grand Cherokee rotors
Jeep Grand Cherokee Caliper Kit 99-04 (Teeves or Akebono - choice is yours)
Grand Cherokee (WJ) outer steering knuckles 99-04
Grand Cherokee (WJ) caliper brackets 99-04 (these generally come with caliper kits)
WJ knuckle flange spacer (JKS - not sure if anyone else makes them)
99-04 WJ/07-13 JK Dana 30 Ball Joints (upper & lower)
Fixed changes in Bold ... just wanted to clarify that XJ D30 lower Ball joints will not work ... well they will I suppose if you like replacing outer knuckles (the WJ/JK lower BJ taper is different)
Old January 14th, 2013, 17:16
blondejoncherokee's Avatar
blondejoncherokee blondejoncherokee is offline
ill be ordering those alloy ball joints when my spicers die on me thats for sure.
As soon as I crest the top i'ma turn driver and floor it!
1998 4.6 stroker , aw4 XJ on 60/14b , 5.38s, grizzly/detroit, cage, 40s, psc big bore box , assist, 3 link,transgo aw4 reprogram
Old January 15th, 2013, 20:02
lamart91 lamart91 is offline
I have a 91 Comanche. So then I will need to get hubs for a 2000/2001XJ instead of using my originals right?
Old January 15th, 2013, 20:15
Ok. I searched the Timken part number and Rockauto has them listed as fitting 1999-2001 Cherokee and 2000-2006 Wrangler.
WJ knuckle swap and 1-ton steering complete Dustys Modified Tech Discussion 70 January 3rd, 2018 11:03
4.0L and ax-15 parts for complete swap gimike812 Arizona For Sale/Wanted 0 July 18th, 2010 17:25
**1992 to 1996 Brake Booster Swap (Parts List)** trekfuel80 Modified Tech Discussion 12 April 20th, 2005 17:59
Wanting cruse-parts list. scoobyxj OEM Tech Discussion 9 February 15th, 2005 13:10
