Old July 8th, 2019, 06:42
Cottontail's Avatar
Cottontail Cottontail is offline
Three-De Off-Road
HVAC Fan not working
The new to me XJ I just picked up (2000 model) doesn't blow the HVAC at any speed or on any setting. I put in a new blower motor resistor, just to rule that out. I was pretty sure that it wasn't that, as research told me that a bad resistor would still blow on #4. I did pull the knob plate off the dash and all the vacuum lines look fine to the center indicator knob, and there are no "burnt" wires leading to any of the other knob plugs (particularly the blower setting knob.
Before I start tearing things apart - it has to be either the switch or the blower motor itself - what tests can I do, and how would I do it to see if I can isolate the issue? I really don't understand wiring and the electrical part of repair.
I saw one post on the internet that said it could be a vacuum leak at the ball behind the pax side bumper, but I was under the impression that was a cruise control vacuum canister.
Dirk DeYoung--Member #176
You'll never leave Harlan alive.
1996 ZJ (200GRND)...2001 XJ (TRALRIG)...2006 XK (TOW RIG)
Old July 8th, 2019, 06:52
Saudade's Avatar
Saudade Saudade is offline
Re: HVAC Fan not working
It is but it also supplies the vacuum operated vents. So if blowing only out the defrost would indicate a vac leak.
First, check the fuse. The you'll need a volt meter (or noid light) to verify power at each side of the fuse, then start swimming downstream. Could be a grounf as well.
Did you test the fan before installing it?
1988 Laredo 2wd Auto, AKA "Grey Ghost", 206K
Old July 8th, 2019, 06:53
RCP Phx RCP Phx is offline
Start taking voltage readings at all the points you get get to.
Old July 8th, 2019, 16:35
MichXJdad's Avatar
MichXJdad MichXJdad is offline
Check the fuse, if it's good unplug your blower motor in the engine compartment and check voltage on the harness side of the plug. Blower motor is a Pita but doable if it's bad. Careful not to over tighten the 3 hex screws holding it in when re-installing, mine easily stripped installing my new blower and had to re-enforce with jb-weld. Good luck
Old July 9th, 2019, 09:49
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
You can also try jumping straight from the battery to the fan connector (it's only 2 wires) to check the fan motor directly.
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old July 9th, 2019, 23:50
EvaB99XJ EvaB99XJ is offline
If you find that it is a dead blower motor you can get to it by removing the bracket that holds the a/c accumulator in place and rotating it up out of the way - that way, you don’t have to evacuate the a/c system.
The only other thing you might need to do is to slightly bend the sheet metal out a bit at the 5 o’clock position to allow the new motor to go back in.
Old July 12th, 2019, 12:29
Cottontail's Avatar
Three-De Off-Road
Well, here is where I am at with this. I checked the fuses and the relay and all them are good.
In researching, I read that when I change the fan speed, I should hear/feel the relay switch activate. That is not happening. I tested the relay with a multimeter and also put a known good relay into that spot as a second test. I felt/heard nothing on either relay when I moved the dash knobs.
I did confirm that the vacuum is good as the actuator rod did it's thing as I moved the center knob from position to position.
So, if I am correct, that tells me that the relay isn't getting power and there is an issue between the relay and the fan switch on the center stack.
Old July 12th, 2019, 18:46
Cottontail's Avatar
Three-De Off-Road
Tried a different switch panel this afternoon. Still nothing.
Old July 12th, 2019, 20:41
JC93XJ's Avatar
JC93XJ JC93XJ is offline
I had this issue. I checked fuses, Vacum leaks and replaced the resistor under the dash. still nothing. took the hvac controler out of the dash to find one of the plugs had became disconnected. plugged it back and the fan started to work again.
Old July 13th, 2019, 06:13
Cottontail's Avatar
Three-De Off-Road
I thought about that also - but I tried a completely different controller, and neither of them worked.
Old July 13th, 2019, 06:14
ehall's Avatar
ehall ehall is offline
have you checked for power at the motor connector and PDC
my '91 beater rebuild
HVAC Air/Vents not working correctly notamos OEM Tech Discussion 6 June 9th, 2015 04:38
1995 cherokee hvac not working birdmanxj OEM Tech Discussion 1 December 13th, 2010 13:59
WTB... HVAC fan. Jes Sierra Chapter For Sale 5 August 12th, 2009 04:14
HVAC not working mrrbby OEM Tech Discussion 6 July 4th, 2007 08:31
HVAC ? RyanM Non-Tech / Off Topic 1 March 25th, 2007 13:32
