Old October 8th, 2019, 08:02
Tcharles3 Tcharles3 is offline
HO cluster to 4.0 swap?
Bought a full cluster from a guy yesterday to swap out the stock one since mine doesnít have a tach. I didnít think to ask the guy yesterday but apparently this one came out of a 1996 4.0 HO. I have a 1994 2D 4x4 with 4.0 and a 5 speed. Will this work out? I saw mixed answers online.
Old October 8th, 2019, 08:12
Just realized Iím an idiot new to the Jeep world. Any chance someone could delete this topic? Lmao
Old October 10th, 2019, 08:45
XJRENEGADE XJRENEGADE is offline
Re: HO cluster to 4.0 swap?
I also am a new guy and member to the . I am in a similar position as you with some questions and some basic understanding of what to do. The Gen. 2, 1991-96 are all supposed to be compatible. I just ordered a used upgraded instrument gauge cluster and am waiting for it to arrive before ordering an more necessary parts. Two parts on my order list will be an oil pressure sending unit (MOPAR part no. 56026779) and a coolant temperature sending unit (MOPAR part no. 56027012). I have located these at 1AAouto.com for $24.95 and $19.95 respectively. There may be better and/or less expensive sources? There are some install guide sources out there as well on this forum and I found one on jeepin.com, XJ Gauge cluster sway that was very helpful. I am unsure if I will need to get additional connections or harnesses to go to the two new sending units. Will wait and see what I get in the mail on Friday first. Also, I haven't found out what I need to do to have the new (used) unit's speedometer changed to match my current miles. Hopefully, the tach. hookup will be automatic but since I haven't done it, I don't know. Hopfully, this helps you out a little and maybe we can get some of our unknown questions answered as well.
Cluster Swap dagr8tim OEM Tech Discussion 5 March 31st, 2009 07:50
cluster swap Q 89xjJe3per Modified Tech Discussion 6 April 16th, 2008 23:23
90 to 89 Cluster swap OverTheHillsATTW OEM Tech Discussion 2 March 17th, 2008 15:17
Cluster swap gbarkan Wanted: Private Party Only 4 April 27th, 2005 05:33
cluster swap Kejtar Modified Tech Discussion 16 July 25th, 2004 20:36
