Old August 4th, 2014, 18:33
iwannadie's Avatar
iwannadie iwannadie is offline
Re: Power lock problems on '99 XJ
Originally Posted by Tim_MN View Post
The first thing to do is to clean and lubricate the locking and latching mechanisms. Use throttle body cleaner and a light oil. I prefer a CLP type gun oil with a long lasting cleaner additive.
I pulled my 97 front passenger side actuator apart to clean and lube and found it to be horrible to reassemble. I don't remember exactly but something about a spring under tension and a rotating piece that kept popping off before I could get a covering plate on it. Took forever for the universe to align and have it all go back together it seemed.
Old August 5th, 2014, 15:32
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
I just spray the cleaner into the whole deal, work the mechanism while spraying, and let it dribble out the bottom.
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old September 30th, 2015, 15:02
Slimdude85 Slimdude85 is offline
I know I'm reviving this thread, but I was having very similar issues with my '00 XJ. I replaced the DDM and PDM, repaired wiring, checked fuses, etc. all to no avail. I was at a total loss. Finally I read somewhere that someone had a wire shorted under the dome light assembly. So I thought "What the heck, might as well check it out." So I take it down and lo and behold, my XJ was born with keyless entry. I proceed to unplug it and try the locks, and they work correctly. No more bound up actuators, tweaker locks or anything. I just don't have operational keyless entry on a vehicle I never knew had it in the first place. The best I can figure is that the receiver shorted out to the unlock circuit and was keeping the actuators in the unlock position, effectively disabling the locking mechanism. Couldn't rock the lock/unlock button or lock with the key. Hope this helps!
Old February 10th, 2019, 07:46
Nimrod's Avatar
Nimrod Nimrod is offline
Degenerate Jeeper
Now this is interesting.
Yesterday, on my Ď99 Limited I found the interior was damp following recent rains. Iím not sure if the door seals have started to leak or if I had left the windows open a crack. When I went to drive it, the door lock actuators started going crazy, intermittently trying to lock and unlock the back doors. I also had water dripping from the overhead console, which I assumed was condensation from the general dampness. I had no idea the issues could be related. I guess I need to take the console out and try to see whatís going on up there.
'91 XJ Power seats are dead: please help Headache OEM Tech Discussion 5 July 25th, 2004 08:06
Looking for someone parting out an XJ mark268 Wanted: Private Party Only 3 June 26th, 2004 19:00
power lock and widows watchamakalit Wanted: Private Party Only 2 June 1st, 2004 13:07
Dumb power lock question... Drewlee77 OEM Tech Discussion 3 March 1st, 2004 21:32
zj steering on xj 90xjDave Modified Tech Discussion 2 December 7th, 2003 01:03
