Old February 9th, 2019, 07:47
Lanser1999 Lanser1999 is offline
2001 Jeep cherokee misfire/runs rough!!!
I have been chasing this issue for a few months now and it is becoming very annoying.
To start off with my jeep never starts on first try, probably the check valve not a big deal. However, everytime I cold start my jeep it will run rough/misfire for a while unless I shut it back off and restart it, then it will run fine. When its warm it runs fine but my fuel mileage hasn't been that great. Any help would be appreciated trying to have this resolved before Winterfest.
I also have a intermittent loud tea kettle noise coming from inside my engine bay, cant find it and is driving me up the wall!!
I also have a new coil pack, and new spark plugs.
Old February 9th, 2019, 10:56
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: 2001 Jeep cherokee misfire/runs rough!!!
Define and explain "fuel mileage hasn't been that great" ? What brand and type of spark plugs are installed ? A 30-40% drop in gas mpg's should make one suspect O2 sensor issues. Have you tested the O2 sensors and sensor fuses ? Have you had the battery Load tested and cleaned/snugged all the battery and alternator connections ? Rough starts can be a faulty check valve, and/or can be one or more drippy fuel injectors.
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old February 10th, 2019, 07:11
Roughly 10 mpg, I have 2 new o2 sensors. I have copper spark plugs. I have not lid tested battery but connections are snug and clean.
Old February 10th, 2019, 07:24
Agreen Agreen is offline
The whistling noise leads me to believe that you have a vacuum leak. Grab a can of carb cleaner (or some brake cleaner) and spray around the intake manifold to locate any vacuum leaks.
Old February 10th, 2019, 07:55
Tim_MN's Avatar
Checked all the O2 sensor fuses, and inspected the O2 sensor wire plugs and wire harnesses for corrosion and damage ? Any bent or pushed back wire plug pins ?
Originally Posted by Lanser1999 View Post
Roughly 10 mpg, I have 2 new o2 sensors.....
Doesn't the 2001 have 4 O2 sensors ?
Bosch or NTK O2 sensors ? It is well proven that the OBD-II Jeep 4.0L and Bosch O2 sensors do not play well together and that Bosch O2 sensors commonly cause the CEL to illuminate and/or cause drivability issues.
Old February 10th, 2019, 12:22
Replaced with Bosch then had to replace with NTK. It has 4 o2 sensors. I’ll have to check the fuses, but CEL is not on. Another thing is when I cold start it and it runs rough if I hold the RPMS around 2k the misfire clears up.
Old February 10th, 2019, 12:36
RCP Phx RCP Phx is online now
Have you ever replaced the injectors?
Old February 10th, 2019, 12:38
I haven’t replaced the injectors yet. Was trying to gather information on how to test them/ how to tell.
2001 Cherokee misfire when cold Lanser1999 OEM Tech Discussion 20 December 22nd, 2018 17:27
1987 Cherokee Renix 4.0 - rough Idle/misfire Godenades OEM Tech Discussion 63 December 16th, 2015 16:30
cherokee runs rough, backfire, missfire, etc 89Cherokee95 OEM Tech Discussion 30 July 18th, 2014 13:57
1993 cherokee very rough idle/misfire offroadxj07 OEM Tech Discussion 3 January 26th, 2011 16:50
89 cherokee 4.0 runs rough nynatv OEM Tech Discussion 11 July 30th, 2009 17:05
