Old November 21st, 2016, 20:32
IndianaJohn IndianaJohn is offline
Trailer package?
My thanks for the help with my rear defrost problem! Now I need some info on the factory tow package.
My 98 Sport has the Mopar receiver hitch installed, however it does not have the trailer light socket. And it does not appear to have been removed by a PO as far as I can tell, as I don't see any loose wiring hanging down. However, a PO may have gotten the hitch from a salvage yard and installed it. So I'm wondering if it could have came from the factory with the hitch installed but no light wiring? I doubt it, but? Is there any sure way to tell if it came with the factory tow package?
Thanks!
Sent from my iPad using Tapatalk
Old November 21st, 2016, 21:13
go1lum go1lum is offline
Re: Trailer package?
It could beb there still. Check behind the rear quarter panel plastic behind the spare. I've seen them tucked back there from the factory. That is where the factory harness plugs in also.
Old November 22nd, 2016, 07:47
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
As suggested, just check behind spare tire and plastic trim. If you install trailer wiring, be sure to get the plug-n-play type adapter and not a universal fit.
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old November 22nd, 2016, 13:22
Trailer package?
And I just had that opened up a couple of days ago while I was sorting out my rear defrost problem..... wish I'd known about it then. Oh well, guess I'll have to open it up again when I get a chance. Thanks!
Old November 23rd, 2016, 11:59
Trailer package?
Well, I dodged the raindrops this afternoon to open up that left rear corner again. The only harnesses I saw plugging into the main harness were the ones going to the left rear taillight and up to the hatch. I didn't even see any place for a trailer harness to plug into. The only empty connector I found was a white connector with a single blue wire coming out of the main harness. Don't know what that was for.
Old November 23rd, 2016, 14:14
Tim_MN's Avatar
Plug and Play trailer wiring is usually a T adapter. A blue wire is usually for hooking up trailer brakes.
Old November 23rd, 2016, 19:31
Trailer package?
I guess I should have taken my test light to that blue wire while I had that opened up. Didn't think about it at the time. So the stock trailer wiring tees into the main harness back there too? So if I find another Jeep in a salvage yard with the trailer wiring, I can just plug it into mine?
Old November 24th, 2016, 06:24
Tim_MN's Avatar
If the donor is a 97-01, yes it will fit any other 97-01.
Google XJ Cherokee trailer wiring adapter and see what it is you are looking for.
Old November 24th, 2016, 08:23
RCP Phx RCP Phx is online now
The blue wire isn't hooked up to anything, it's usually curled up under the driver front kick awaiting a brake controller!
Old November 24th, 2016, 08:43
WB9YZU WB9YZU is offline
NAXJA Forum Supporter
To add:
IIRC, the 5K lb Factory Trailer setup had the Factory Hitch , and an lighting Isolator/adapter assembly behind the spare tire. Can't miss it, it's huge and has relays on it to control the trailer's turn signals.
Old November 24th, 2016, 23:34
Trailer package?
Well, looks like my Jeep must have a salvage yard donor on it then. I know it's a factory hitch, as it has the "MOPAR" sticker on it and the bracket for the trailer socket just like the factory hitch on my 99 Ram. Oh well, guess I'll have to scavenge the wiring somewhere then. Don't really need a brake controller with my little trailer, but maybe I can find another use for that blue wire...
Old February 9th, 2019, 06:52
pats2001 pats2001 is offline
I have a 2001 without the hitch (trailer tow package). Can I get a factory wire harness and plug it in or is the harness different?
Old February 9th, 2019, 07:00
The wiring harness is the same. You have to buy a converter/adapter for the trailer wiring.
Old February 9th, 2019, 07:15
So its not just get the factory harness and plug and play? I've just had bad luck with aftermarket trailer wiring and wanted to stay factory if possible.
Old February 9th, 2019, 08:04
No, you "HAVE" to get the converter.
1994 factory tow package trailer wiring damaged in rear ender, need to hook back up xjtrailrider OEM Tech Discussion 3 July 16th, 2014 02:21
Biggest Uhaul trailer I can tow with XJ w/ tow package? 01_XJ Tow Rigs and Trailers 33 August 4th, 2010 07:05
WANTED: 97+ Factory Tow Package trailer wire harness.. muduck18 NAC Classifieds 0 June 29th, 2009 07:51
Running wires for a trailer on a XJ without a towing package? Plays For Jeeps OEM Tech Discussion 7 January 7th, 2008 17:34
trailer package wiring??? RNMedic OEM Tech Discussion 2 September 5th, 2003 20:38
