Jeff-97XJ
- Atlanta, GA
My stock auxilary fan stopped working.
I bought a new one at AutoZone and put it in.
NOW- the new fan doesn't always shut off when I turn the XJ off. My coolant temp is around 190° so there is no reason for the fan to stay on, I have to pull the plug on it to get it to turn off. It has run over 20 minutes, without shutting off, so now I just pull the plug
Also, if I am running the A/C and turn off A/C, the fan still runs.
If the XJ is ice cold, like in the AM and I run the XJ for 10 minutes, this doesn't happen.
I replaced the coolant temp sensor in the water pump housing and no change to condition.
Any ideas what this could be?
Thanks,
JP
Thanks,
JP
