To-do List
MoparManiac
Amherst, NH
Might as well keep the tradition going of myself starting this thread :laugh:
- Swap out oil pan dipstick for locking one
- Spend some time tuning the motor (ideally I'd love to get on the dyno)
- Swap out iron heads for aluminum heads (pending my uncles time)
- Brace air bumps back to frame
- Fix leaky tires
- Get spare leaf springs
- Fix rear diff breather
Ideal list:
- Fix everything. Rusty floors and rockers, cracked frame, open engine up and find out how bad I hurt it hydrolocking it, new tires since they're dry rotted and go flat in a few weeks, skidplate for winch connections, fix DW, blah blah blah.
Probable list:
- fill tires back up
- throw spare engine and hoist in bed
- throw beer, hammock, food, clothes in bed
- throw some more spare parts in bed
- drive down
Stuff I will probably do:
-Sector shaft brace/winch skid
-Double sheer drag link ends
-Change oil
-Grease stuff and tighten bolts
-Pull front cover to check Locrite and change fluid
-Finish building and swap in new driveshafts, current ones become spares
-Find a pair of spare 14b shafts and long side 60 shaft
Stuff I probably won't do:
-Get gauges working
-Get AW4 shifter working
-Fix tires instead of just filling them every trip
Tow rig stuff:
-Bump timing
-Slightly bigger injectors
-Fix dragging DS rear brake
-get tires that arent cracking open like eggs on sunday morning breakfast
-new rear calipers
-trim front bumper air dam thing
-coat wheels and tires with 100000 layers of armor all to repel pee
-install chromoly shafts in front.
-install new 7075 tie rod and goferit flip insert.
-weld in skids for lower control arms.
-mount all 4 shocks with new brackets so they are the proper lengths.
Finish up rear 4 link
finish up rear bob
paint stuff
put back of cage back together and add tube
buy and install frt airshocks
reinstall fuel pump and cell
not break anything Memorial Weekend
Hmm...maybe Ill add... My Jeep is fine....maybe just repray tailgate and inner doors because I have OCD.
On my 68 Charger...
Order:
-New AM gauge cluster with wiring
-PG shifter
-Shifter
-Various misc crap
Install:
- Entire interior, finish the drivetrain conversion alignment, possible respray/stripe
Reality - Will likely not get done....I now work 50-70 hrs a week with barely any time off...AND my two chargers are at my parents house/garage.
Need a house ASAP
On my 68 Charger...
Order:
-PG shifter
-Shifter
-Various misc crap
Install:
Need a house ASAP
You actually going?
-Install KJ e-brake cable
-Install brown dog motor mounts/brackets
-Install 3 Link
-Install transfer case skid plate
-Install gas tank skid plate
-Front end alignment
-Build and install new track bar to get rid of DW
-procure 33 inch tires
-build a rear bumper (maybe)
-Try to get my sway bar installed after WJ knuckle swap
-Install Leather ZJ seats
-Depending on results of TB and alignment, maybe install steering stabilizer for added insurance against DW
I don't think he knows this is for NACfest.
At least I don't think he's going.
And pretty sure he's not taking the charger down.
Roadkill did an offroad charger, so can Rick.
Since I already bolted 70% of the junk from the 2 xjs I've killed since last nac fest to this one I'm feeling confident but the list as it sits now.
-Skids
-CB
-Unweld my crosmember from the jeep
-zj disc brakes
-water pump, hoses, t-stat
-IRO tie rod
-steering box brace
-patch hole in the floor
-make doors removable
My to-do list:
-Register for NACFest
-Mount Fire Extinguisher
-First Aid Kit
-Install CB Radio
-Install front locker
-Install ZJ tie rod
-Install SYE
-Install IRO Double Sheer Track Bar
-Paint stuff when the weather gets warmer
-Install brown dog motor mounts/brackets-DONE
-Install 3 Link
-Install Leather ZJ seats-DONE
I need to seriously get working...
-get tires that arent cracking open like eggs on sunday morning breakfast check
-new rear calipers in transit via fedex
also going add sliders maybe, and i have to order the special "land rover tow hook loop" for a front tow point.
-new rear calipers check
-trim front bumper air dam thing check
also going add sliders maybe, and i have to order the special "land rover tow hook loop" for a front tow point.also going add sliders maybe, and i have to order the special "land rover tow hook loop" for a front tow point.
am i the only one updating this?:laugh:
