Important
Barracks inspection this morning:
Brought the Jeep back to school to have the doors put back on for winter...
Guess I should consider myself lucky, my 4.0 only seeps oil and not enough to notice at checks...
99SJ 'Exhaust header leak though... Again' Ex
Didn't the 4.0 come from the factory with a leaky rear main?
The 5.9 leaks...but not more than 1 quart between 3k oil changes.
mac 'LJ has had a rear main since I've owned it' gyvr
Thats the one spot mine has absolutely no oil residue at...
What are you guys doing for trans fluid service? I flushed mine then threw a filter and an oil cooler on it like 3 years ago and the fluid looks and smells like the day I put it in...
99SJ 'Shaffers Synthetic trans fluid' Ex
I put a rear main in mine 60k ago. It was dumping it as fast as I was putting it in.
I serviced my Trans 60k ago too. Haven't touched it since. Looks dark and smells bad but I'm ok with it. 278000 it has a right to smell funny.
I put cheap advance fluid in it.
Tcase gets a drain and fill one a year when I service the ujoints before wf.
Did a fluid and filter change on my trans at 90K. Never had a problem. Now at 168K, it's acting funny.
Still working to correct it.
i like the leaky oil. keeps all my front end stuff from rusting.
i wish there was some oil component in the rear to keep that lubed.
small hole in the gas tank?
mac 'rust sucks' gyvr
Rear pinion seal. as it leaks the yoke shoots gear oil all over your rear end.
