Old May 14th, 2007, 19:21
fluidmotion fluidmotion is offline
power steering pump
so i installed a new P/S pump and lines on my XJ last weekend and i noticed that when i drive around there is a really high pitched whistle when the pump builds up pressure (i.e. turning the wheel). but when i stop and am idling or just not steering at all the whistle goes away. its not the sound like the pump is low and i know its not because i checked the fluid multiple times. I also took my time and bled the system and made sure all the air was out. it drives fine down the road, just has the whistle. Is the whistle normal? like some sort of a pressure release built into it?
Old May 15th, 2007, 08:26
XJJack XJJack is offline
Re: power steering pump
Might be the belt sliping, tey to tighten a bit more and see if that helps.
Old May 15th, 2007, 10:33
j-nut j-nut is offline
also, make sure you didn't kink of pinch any of the lines. that could cause a squeal.
Old May 15th, 2007, 13:35
87manche's Avatar
87manche 87manche is offline
did you bleed the steering system after install?
could be the pump cavitating air.
In need of power steering pump Chippo Wanted: Private Party Only 1 February 22nd, 2007 14:16
Power Steering Pump fed_up_mp OEM Tech Discussion 0 September 13th, 2006 04:47
Power Steering Pump? jeepboy_90 Modified Tech Discussion 5 August 1st, 2006 09:56
Thread size/pitch of power steering pump/steering gear inlet/outlet? hotrod22 OEM Tech Discussion 7 January 16th, 2006 13:38
Power Steering Pump GoalPoster OEM Tech Discussion 11 May 29th, 2003 04:19
