Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Tools and Garages
Tools and Garages This is a place to share about the tools and workspaces used to craft your latest masterpiece.
Thread Tools Rating: Thread Rating: 18 votes, 4.78 average. Display Modes
  #46
Old May 2nd, 2007, 07:54
alwaysready's Avatar
alwaysready alwaysready is offline
Re: Harbor Freight vs Costco Portable 12v Air Compressor - In Depth Review w/ Pictures
Originally Posted by Frank Z
I used an MV-50 for a couple of years. It died this past weekend. The bearing on the bottom of the connecting rod came apart.
http://www.colorado4x4.org/gallery/f...6/1/OCG007.jpg
password protected picture
Old May 2nd, 2007, 07:55
Frank Z Frank Z is offline
Old May 3rd, 2007, 05:45
WoodyWoodchuck's Avatar
WoodyWoodchuck WoodyWoodchuck is offline
I just bought the MV-50 based on this and other writeups and tried it out last night. 235/75/15 from 10# to over 35# in a minute or less! Didn't really have enough time to time it, pressure went up much faster than I would have expected for such a little compressor. The gauge sucks and is way, way off but I can use it as a guideline for start/stop and how much was inbetween. I was planning to add a tank but as fast as this thing is with my little tires, I see no need for it.
I surf fish NC beaches and 22# has been my pressure in the soft, deep stuff. Having this little jewel on board I can try going down lower with no worries about hitting the hard road with really soft tires. Thanks for turning me onto a great little compressor!
Old May 4th, 2007, 19:43
ChuckstrPT's Avatar
ChuckstrPT ChuckstrPT is offline
NAXJA Member #791
Originally Posted by sidewys xj
I have used the cosco one for about two years mine came from cheker auto its the same thing. I hard mounted mine use a 2/1/2 gallon air tank with a 100 psi pressure switch that really helps out with the first tire. for what I paid for it its great I could buy at least 4 of them before I could buy a vair or extreme air so its worth it to me I even bought a spare if mine quit but it has not happend yet. great little compressors.
Where did you mount yours??? I'm looking at that right now...I don't think there is enough room in front of the brake master.
Thanks!
Old May 7th, 2007, 22:23
selarep's Avatar
selarep selarep is offline
Originally Posted by 2001XJ
I jjust bouth the maxxQ and its way better than the #MF-1040, the #MF-1040 is way cheaper but it takes longer to fill and its just not as good at the maxxQ.
The little sir fitting on the maxxQ is HOT as heck when you disco the hose but it's one heck of a nice compressor. I bought it because of the write on here and i love it!
plus... costo has that lifetime warranty.
Old May 9th, 2007, 01:38
Mutant_Xj Mutant_Xj is offline
I was just at pepbys looking for an air compressor and they didn't have the tsunami. They had one made by Master Flow called the special ops. It comes with a battery pack and light. Does any one know if this is any good? Its rated at 150 max psi, max displacement 1500 cubic inches/min., I'm assuming its similar but don't know.
http://www.jcwhitney.com/autoparts/P...017698/c-10108
Old May 9th, 2007, 03:31
selarep's Avatar
it looks like a good compressor but for the price, you can get 2 of the qmaxx's/tsunami's.
Save your $$$ and get the qmaxx's/tsunami's.
Old May 12th, 2007, 21:13
Originally Posted by alwaysready
its physically a smaller compressor.
so is the special ops one or whatever theya re calling it.
the spc ops one is pretty much the same one as that yellow one. the red tsunami is larger and more powerful.(hence more money.. )
$28.00 pep boys ( the smaller cheaper one)
Model mv-40 aka mf-1040 at pepboys
SPECIAL OPS M45 CORDLESS AIR COMPRESSOR /SEARCHLIGHT $99.00 at jcwhitney(think it was 89 at pep boys cant remeber).
same compressor as yellow one above except added options of flashlight and rechargeable battery that seems to work on either the flashlight or the compressor(better, only in options)
$59.00 pep boys, had 10.00 rebate. ( the BEST one)
model MV-50 aka MF-1050 at pep boys
i got one for me one for my dad and now i think the rebate is over..
Old May 13th, 2007, 00:06
I missed that in the post earlyer. I did a bunch of research and figured it out later that night. I went back to pepboys and asked the lady working there about the tsunami and she was clueless. Oh the battery for the special ops only lasts 8-18 minutes and the extras kinda look cheap. but yeah I want the tsunami but cant find one. No costcos around and I dont know anyone with a membership.
Old May 13th, 2007, 08:12
Pro Stock John's Avatar
Pro Stock John Pro Stock John is offline
Great writeup!
Old May 13th, 2007, 08:32
xjjeepthing's Avatar
xjjeepthing xjjeepthing is offline
I have the Tsunami from Pepboys. Works great. Hard wired through a realy and a switch in my switch panel.
Old July 13th, 2007, 13:18
IllianaXJ's Avatar
IllianaXJ IllianaXJ is offline
Back from the dead with a link for the MF1050 on eBay.
Decent price, I'll probably pick one up for the DD.
http://stores.ebay.com/Auto-Parts-Sa...QQfsubZ0QQtZkm
Old July 13th, 2007, 13:23
MisterFubar MisterFubar is offline
Thanks for the write up, I keep eyeing the HF unit everytime I'm in there but I haven't been able to bring myself to buy one.
Anyone using either of these to run ARB's?
Old July 13th, 2007, 17:06
selarep's Avatar
I Love my Costco one, the qmaxx/tsunami. It has worked flawlessly since I bought it and I air up everything.
Old July 13th, 2007, 19:41
ChuckstrPT's Avatar
NAXJA Member #791
That's the one I've got Anyone hard mount that under the hood? If so WHERE?? I can't find a place to fit it.........
Rate This Thread:
OBA from Harbor Freight? tupton Modified Tech Discussion 15 January 21st, 2007 19:27
harbor freight on board air compressor outlander Modified Tech Discussion 42 August 16th, 2006 21:50
Harbor Freight compressor Timber Modified Tech Discussion 2 December 6th, 2005 21:09
Harbor Freight Tools ????? Eagle Non-Tech / Off Topic 22 February 26th, 2004 11:49
