Old March 17th, 2011, 23:11
mgt's Avatar
mgt mgt is offline
NAXJA Member #653
Re: All Gauges keep going dead, then airbag light comes on
mine did the same thing. took it to a speedo shop and they check all connections , made a couple solder a coupler connections and all is good now. its the solder connections on the circuit board. check local speedo shops.
Old March 18th, 2011, 12:27
Dragonslayer Dragonslayer is offline
Back again. On my '93, I went and dissected the gauge connector (on the harness end)
wire-by-wire. While I had it apart, I cleaned each connector using electrical contact
cleaner and a set on tiny self-made cotton swabs (I was amazed who much black soot
came out of each connector). I then gently squeezed each connector at the waist with
a pair of needle-nosed pliers so that they would grip each pin more strongly and put
everything back into the plastic connector block. I applied some dielectric grease on
each pin and put it back together. It took a bit more force to get the connector to slide
and snap onto the socket on the gauge pack - which I took as a good sign as each connector now grips it's respective pin more firmly.
I fired the car up and took it for a spin.
No change. The tach and speedo needles continue to dance and bounce and wave as
though they are both flippin' me the finger.
An electrical engineer balked when I told him that I had applied dielectric grease on
each pin. He never uses the stuff. Oh great ...NOW he tells me.
I'm open to any other ideas.
My '98 is OK. All I did was to press on the gauge pack further into the dash. I had
used the tips of all of my fingers and needed so much force that I thought I was going
to break the lens, or smash the gauges through the firewall. All is well since.
Old March 22nd, 2011, 10:03
QCXJ8879's Avatar
QCXJ8879 QCXJ8879 is offline
Having the sam problem with my 99 just started last night. We were wheeling all weekend and everything worked fine. I know we were on some washboard roads and maybe rattled something loose. I tried to pull and clean the connectors with no luck! Anyone making any progress on this problem?
Old March 23rd, 2011, 10:12
dishner dishner is offline
I know it doesn't help much but this worked for me too. I can't believe the electrical problems these things have. In my 98, the dome light stays on all the time, until I turn on the rear defroster, then it goes off. Then the defroster won't auto-shutoff, until I turn on the domelight. Vicious cycle!
Old March 23rd, 2011, 11:08
QCXJ8879's Avatar
I pulled apart my dash and cleaned every plug I could find and used dielectric grease and my heap is back to normal. Well atleast for now. lol
guages die when airbag light comes on, wtf? check engine light on rockhard4x4 OEM Tech Discussion 9 June 20th, 2009 07:34
all dash gauges are dead all of a sudden, help RWKHausSupply OEM Tech Discussion 8 August 17th, 2008 11:51
gauges dead CBB311 OEM Tech Discussion 4 April 7th, 2008 12:27
01 gauges and check gauges light Ramsey OEM Tech Discussion 2 October 7th, 2004 00:01
Lights dead in gauges and console... sportsguy Modified Tech Discussion 12 June 16th, 2004 06:20
