Old January 29th, 2007, 14:18
kd5dwy's Avatar
kd5dwy kd5dwy is offline
Mounting an Amateur Radio
I'm trying to figure out the best place to mount my 2M rig in the '87 XJ. Any suggestions?
Has anyone successfully mounted in the center console in front of the shitfer (below the ash tray)? Not sure if there's enough room there...
Old January 29th, 2007, 22:14
whatevah's Avatar
whatevah whatevah is offline
It's Yellah!
Re: Mounting an Amateur Radio
inside the console, or next to it? I saw a government XJ with 3 or 4 radios mounted to the side of the console, worked pretty well. it's also a common spot for CB radios. I don't think that there is room inside/under the console for one to fit, it gets warm anyhow, so I don't think you'd want it there.
Old January 29th, 2007, 22:18
artsifrtsi's Avatar
artsifrtsi artsifrtsi is offline
The guy that I got my Chero from said that a small radio fit there, and the wiring is still all there for that, i don't know if I'd realistically put one there though, not without opening up the bottom of that bin first...
Old January 30th, 2007, 09:36
karstic's Avatar
karstic karstic is offline
MY Ft7800 is mounted to the dash panel underneath and to the left of the steering wheel
Old January 30th, 2007, 10:27
casm's Avatar
casm casm is offline
Which model of radio is it? If it has a remote faceplate, you could always put the transmitter under the rear seat and run the controls to wherever you want them to be.
Old January 30th, 2007, 10:37
CHUGLYxj's Avatar
CHUGLYxj CHUGLYxj is offline
x2, this is what I am planning on mine.
If you do not have an OHC, you can mount it to the roof between the sunvisors.
Old January 30th, 2007, 10:42
casm's Avatar
One other option I've been considering is mounting the transmitter inside the passenger rear fender - there's not a lot else that can go in there due to space constraints. Of course, it would help if I quit being distracted by other things and actually bought the radio, too
Old January 30th, 2007, 13:01
kloker's Avatar
kloker kloker is offline
I'm studying for my license too, and I plan to run a 2m in My XJ. I've been periodically checking on eBay, where you can occasionally find police radio mounts removed from wrecked or stripped police cars. They come in a ton of different configurations. I sort of like the ones that mount under, and then come out from under, the side of the center console (so no visible holes are drilled in the floor or the console), then have an upright with the bracket mounted at the top. Some have adjustable height and angle, too. I thought of getting one of these and adapting a slide or quick-detach mount to it, so I can use it. I also thought of modifying one of these where it comes out from under the console (or just building my own base part) to be detachable, so that when not running the radio, the bracket is not in there either, except a small part of the base sticking out from under the side of the center console. My plan is to use one of those police brackets off eBay with my own mods, maybe using parts from camera or GPS mounts for a motorcycle, or possibly a modified part of a Panavise mount.
Just some ideas I've been kicking around.
Old January 30th, 2007, 13:17
rpyne's Avatar
rpyne rpyne is offline
x2 for one radio. If you need a bunch of them, you can get an aftermarket shelf that mounts on the visor mountings and hang the radios off of that. I have one set up to hold five radios (I'm on the Sheriff's emergency communication team).
It is a perfect place for a remote head to be mounted. Even if the whole radio would fit, it would not give adequate ventalation to properly cool your radio.
NZ7K
radio shack 40ch CB radio $25 homebrew SoCal For Sale 1 December 2nd, 2006 12:07
Dual radio mounting azdesertrhino Modified Tech Discussion 17 January 8th, 2006 14:22
Amateur radio operators? ECKSJAY NorthWest Chapter 19 December 9th, 2005 05:28
Linux for an amateur jml1911a1 Non-Tech / Off Topic 3 June 21st, 2004 22:55
Winch Mounting (types of mounting) Lunatic728 Modified Tech Discussion 13 January 7th, 2004 09:03
