OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
Broken Exhaust Bracket-- How to Fix?
I just figured out the source of a knock I had, a broken exhaust bracket has the exhaust bouncing around and knocking. Whats everyones experience with fixing it? Should I go to a welder? Can I get away with putting a rubber washer between the exhaust and that crossbeam thing its resting on for the time being?
#2
Re: Broken Exhaust Bracket-- How to Fix?
Yeah, you can but watch out for the washer melting.
Just take it to an exhaust shop and they can probably fix it for you in about 10 minutes. |
#3
Did you break the u-shaped piece on the exhaust pipe, or the chunk on the crossmember?
I broke the u-shaped piece a number of times.... until I figured out my motor mounts were shot.
ChiXJeff Lifetime member "Jeeps are Cherokees. All other models are wannabes." Deb. K. |
#4
Thread Tools | |
Display Modes | |
OEM Track Bar Mount Bracket broken? | Mdub | OEM Tech Discussion | 2 | November 22nd, 2006 12:45 |
Broken Axle= Broken Ball Joint? | jrowell | OEM Tech Discussion | 22 | May 15th, 2006 18:20 |
Broken eye | el_roy1985 | Modified Tech Discussion | 3 | February 20th, 2006 23:30 |
Broken Exhaust Manifold Studs | Rick Anderson | OEM Tech Discussion | 11 | February 2nd, 2006 12:54 |
heat/leak exhaust/new exhaust. | TheManch | Modified Tech Discussion | 5 | May 27th, 2004 17:28 |
