Old October 10th, 2020, 10:18
RCP Phx RCP Phx is offline
Swapping out to Led's?
I'm changing out all my lamps to led's on a 2000. What I don't know is the type and quantities of the instrument cluster lamps and a list so I can choose a color depending on whether it's a general back-light or a specific gauge/idiot light? I'm trying not to tear it down just to place a order but put it back together in the mean time while I wait!
Old October 10th, 2020, 10:23
Re: Swapping out to Led's?
Another question I have for those that have done this, in the case of indicator/idiot lights do you get more light/color when using a white light on a colored lens vs a matching color lamp?
Old October 10th, 2020, 19:27
Took a good look at it this evening, everything is backlit together so the only thing I don't know is the quantity and the type. I will use nothing but white leds.
Old October 10th, 2020, 20:08
camojeep88 camojeep88 is offline
cany help you on bulb count but I do have experience with doing the LED swap in my renix. I just got a random selection from local autoparts stores. I did notice a difference in brightness going from the standard to LED but the issue I had was inconsistency of the color itself. I see it a lot in my line of work being an electrician and the issue is them ranging from 5500-6500k in color which is more on the blue side. Also the ones I got were not dimmable. it was either on or off. Just make sure whatever you get has the ability to be dimmed if that matters to you and personally I wouldn't go anything above 5000k which is more of a pure white. Id order a couple extra just in case one goes out you are guaranteed the same color
Old October 11th, 2020, 07:00
asymptonic asymptonic is offline
Yeah, I do a lot of work with LED lighting outside of automotive and that's kept me away from doing it in the instruments. The quality of the light is annoyingly 'dead' if you can't get a high quality LED with a warmer color temperature. In and around the house it has to be 2700K. Even 3000 sucks to my eye.
1998 4.0 I6, AX15, NP231
Old October 11th, 2020, 07:07
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
youll want 194 leds:https://www.amazon.com/Yorkim-Genera...Y2s9dHJ1ZQ ==
As camo said led dont dim much, I have my whole dash as led. They dim some but not as it was stock. Also you want the 194 bulbs (like the link) that have the leds positioned around (360) and not on top or you will see the lighting between rpm/mph will be darker than the rest.
pretty cool upgrade though, makes everything a crisp read out.
Old October 11th, 2020, 07:48
I've already ordered all the lamps, the other one in question was the type 74 which is used for the indicator lights in the cluster and some of the other dash components.
Old October 11th, 2020, 08:08
I forgot to add that I'm buying everything in 6k white, I've found that to be the best. I have converted my house and garage to that and they work great with all my IR cameras in providing the needed spectrum to get color at night.
Old October 11th, 2020, 08:29
I've already done 2 other cars and they turned out great. The trick here with the cluster will be to test and mark all the lamps for polarity so as to get it done in one shot and one assembly of the dash!
Old October 11th, 2020, 09:02
Any chance you can snap some before and after photos?
Old October 11th, 2020, 09:24
That's already planned!
Old October 11th, 2020, 10:02
I just received my 3157's and the 194's, I went with the sealed 194's because they also go in the floor console, kick panel, over-head map lights and clearance lights.
Old October 13th, 2020, 07:17
So far it's made a un-believable difference. I've got the third brake light done (waiting on new taillight lenses), the cargo light and the front dome/courtesy lights done, and the center console shifter lights. I started on the kick panel lights but they were not what I expected(1156 vs the 168 the owners manual shows). The kick panel lenses are heavily dis-colored by high heat but I'm not having any luck finding those.
Old October 13th, 2020, 20:04
The pics of the taillights didn't turn out that great, but the console one's did.....
Before...
After...
Old October 13th, 2020, 20:23
Anak's Avatar
Anak Anak is offline
Stranger
Which bulbs did you use for the third brake light?
I am looking at changing those to LED to go along with a flasher module. If you have some you are happy with I would like to know what those are.
swapping aw4 1slowxj Modified Tech Discussion 3 December 30th, 2014 08:07
swapping out a 2.8 to 3.4FI Gregor Modified Tech Discussion 1 February 2nd, 2008 15:20
Swapping in Mj d44. GrapeApe Midwest Chapter 10 July 6th, 2006 21:15
swapping the 8.25 for a d-35 jeepnuts311 Modified Tech Discussion 3 June 15th, 2006 13:22
swapping 8.8 for D35 BLUTO Modified Tech Discussion 16 July 26th, 2004 07:30
