jeepnuts311
- Atlanta, Georgia
my moms 95 auto 2wd cherokee ate up its rearend and needs a rebuild or replacement, strength is not an issue on this jeep, it is 100% grocery getter.
i have a dana 35 out of a 1990 xj that i just swapped out for a dana 44.
i will be putting the spider gears back in and i wanted to swap it for the chryco, but the snout of the pinion on the dana 35 is about 3" shorter than the chryco, will i need a driveshaft from a 2wd with a dana 35, or will the stock d/s work?
i know its unusual to swap from stronger axle to weaker axle, but a free down-grade is better than dumping money into a stock axle for a rebuild.
i dont know whats wrong with the chryco, but it sounds like horrible backlash and also bad bearings.
thanks
-tim
thanks
-tim
