maxbrake, when I was trying the zj fan clutch mod my mounts were tired but not ripped and my trans mount was shot also but it was moving at least an inch power braking in drive. don't recall how much in reverse but I am sure an inch the other way also. Ive since gone to diy solid mounts and no more movement.
The simple answer is yes. It's going to move in every direction. Fore/aft should have the least movement of the mounts are in good shape, but when you're pounding around on the trail the drivetrain will move an inch or more in every direction.
I'm always impressed with the notion of chassis flex. How can a box structure (XJ) flex as much as people suggest. Even if the steel is pretty thin, the overall box structure should provide a lot of rigidity. But apparently it happens because lots of people have reported fatigue cracking. My thought is that major flex mostly happens during rock crawling when the suspension is either at or near max extension/compression. I suspect that light trail work is not an issue.
