Chadd
- Carlyle, IL
Well after searching and reading here I have decided on either a RE 3.5" or 4.5" superflex for my 97 Country. I plan on running 32's or 33's, will have a winch mount front bumper with winch at some point, I don't mind a little trimming but would like to avoid it if possible. I am leaning toward the 4.5" along with SYE.
Now to the questions.
1. Who is the best "no bull" RE dealer that will steer me straight?
2. What options should I get with the lift that will fit me best in the long run? Options I have read about listed below please feel free to add any.
3. I have read that getting adjustable UCA and LCA is a good idea, what is the concensus on this, is it worth the extra $$? Would I be better off getting the non adjustable and upgrading to Long Arms later if needed?
4. I also read it may be a good idea to replace the standard 4.5 springs with 3.5 ZJ springs if you are going have a winch in front.
5. I have read that the Gen2 disco's are junk and to get JKS. Are the Gen2 that bad if you are not frequently disconnecting them?
6. Is the trackbar that comes with the 4.5" kit good enough? Is an additional mount required for it?
7. Will a front drive shaft work for the rear if I use the RE hack-n-tap on a 97' 242 with 8.25? I have read both, that it would and that it wouldn't.
8. Will shims more than likely be needed for the rear axle? If so what is a good angle to start with?
9. Any reasons to get the 3.5" over the 4.5"? Seems like the 4.5" is a more complete kit. Is there noticable difference in stablity do to the extra 1" in height?
10. What about the rest of the front steering components, will stock set up in good shape be ok or should it be upgraded with the lift install? If so any recommendations here?
11. Are there any gotchas with the complete kits? Any extra stuff that is needed that doesn't come with the kits that would be required for the installtion?
Thanks for taking the time to look,
Chadd
Chadd
