was that a reply to my post?
Yes, never heard anyone else complain or talk about that same issue of mixing in radiator.
I just read about this not to long ago on another forum.
Of course it could be the same guy posting there too. LOL.
There is a finned aluminium looking cooler in there.
Somebody showed a picture once. Resembled this:
https://www.summitracing.com/parts/...MIm7Dv4dWA5wIVFo7ICh0APABYEAQYAiABEgJP7vD_BwE
Said it leaked somehow and it was all down hill from there.
I've had this radiator, CSF 3 core, for about 12 years plus. This is the first I had ever heard of it as well.
Apparantly it's not that uncommon, from what I'm hearing from others once I tell them what happened. One guy said that's why he bypasses the radiator all together and just uses a separate tranny oil cooler.
So far the fluid color is getting more red(redder?). I'm just on my 6th gallon and this is getting expensive to be buying all this tranny fluid.
On a side note, Walmart has the fluid for way cheaper than O'reily's...$13 vs $20+
On another weird note, the Walmart brand of tranny fluid is $3 more than the Valvoline brand...
I just got my XJ back together, I disconnected the trans cooling lines from radiator and bought a simple external cooler (~$50). Never had the issue, but this is cheap insurance!
NOW WE TALKIN!Picked up a set of Corbeau seat brackets today off CL.
Did some more troubleshooting on the head. Passed the block tester. Gonna just watch it for more signs at this point, I think it’s ok. Maybe I’ll just buy an LS when I see one
NOW WE TALKIN!
nice. you doing harnesses?
I'm slowly headed that direction. Almost rolled it over the front last time I was out. Already bought harnesses. Will prolly do a harness bar to start with just to get them in while I'm deciding on cage designs. These days there are a couple pre bent options for hybrids.Not unless I decide its time for a cage. Which unless I start getting out more often I don't see happening.
150 for front and back.
Sent from my SM-G892A using Tapatalk
So the new brakes work okay. Still feels like there may be air in the system, but I've bled the crap out of the lines. Need to check all the soft lines. Moving at the end of this month so will get back to it after that.
wait, where ya moving to?
