Old April 11th, 2009, 10:13
Achmed's Avatar
Achmed Achmed is offline
H.D. Offroad Engineering Shackle Relocation Kit
Man, I cant believe I didnt do this sooner. My shackle angle is now perfect, got 1.25" of lift in the rear to account for extra weight and the ride is EXCELLENT! No more bumpy feeling in the rear like when my shackle was almost vertical. Now I have to paint them.
WOOT!
Old April 11th, 2009, 10:17
dgrigorenko's Avatar
dgrigorenko dgrigorenko is offline
Re: H.D. Offroad Engineering Shackle Relocation Kit
i was looking at doing this, but i am already kind of ass high... so it added 1.25 to the rear lift? just looking for for clarification
Old April 11th, 2009, 10:18
Achmed's Avatar
Yes about 1.25"
Old April 11th, 2009, 10:22
RedHeep's Avatar
RedHeep RedHeep is offline
NAXJA #1499
I didn't get that much lift, maybe 3/4" or so. It depends on what shackle you're using I suppose. If you have a lift shackle, you could go back to a stock one and negate the extra lift.
The little lift it brings the rear up is certainly worth the difference in performance. The '91 already has them and the '96 will get them soon enough.
Old April 11th, 2009, 10:27
POLAR_JEEP_04's Avatar
POLAR_JEEP_04 POLAR_JEEP_04 is offline
NAXJA Member #2130
i will get getting a set as soon as money allows. I already sit .25" to .50" taller in the rear so I will most likely add a spacer to the front at the same time
Originally Posted by XJ&CHZ4ME View Post
Some see this as a silly online jeep club.........we are more than that, we are like family.
Buy from sponsors to support those who support our club!
http://sponsorship.naxja.org/
Join ... http://www.naxja.org/html/membership_faq.htm
Old April 11th, 2009, 10:29
Achmed's Avatar
I also keep a bunch of gear, a heavy gear box, 60" HiLift, a 20lb C02 setup, (2) 12" subs and an amp in the rear of mine, so I needed the extra boost.
Old April 11th, 2009, 10:31
NAXJA Member #2130
how much did it change the pinion angle?
Old April 11th, 2009, 10:33
Achmed's Avatar
+/- 1*
Magus2727 Magus2727 is offline
How much did it effect the pinion angle? it looks like it would put it up a few *
Guess I was a few min short...
How is it + or - 1*?
Old April 11th, 2009, 10:34
Ryan93 Ryan93 is offline
where did you get them at?
Old April 11th, 2009, 10:35
NAXJA Member #2130
http://www.naxja.org/forum/showthread.php?t=956630
or
http://www.hdoffroadengineering.com/...relocation-kit
H.D. Offroad Engineering frame stiffeners BRIANHO13 Vendor Advertisements 238 May 22nd, 2017 10:42
H.D. Offroad Engineering Shackle Relocation Kit Achmed South East Chapter 8 October 21st, 2009 17:50
Installed HD Engineering Shackle Relocation Brackets. Write Up Inside. Mosephus Jeep Picture Showcase 8 January 23rd, 2009 15:33
H.D. Offroad engineering frame stiffeners BRIANHO13 Vendor's Specials 2 October 17th, 2008 14:34
