No Power to BOTH cig lighter and aux power
bucklahoo
Ohio
2000 XJ
all a sudden power lost to both outlets, everything else seems fine
looks like fuses are OK, going to swap them out just in case
where can i start to look into this problem?
power distribution center under hood? certain ground somewhere?
like i said just stopped all a sudden
thanks
I don't know if this pertains to a 2000(hopefully someone comments to confirm or deny) but on the early models there's a brown wire that comes off the ignition switch. That brown wire connects to the cig lighter outlets. It's a known trouble spot at the wire so you could check there and look for any melted wires, discolored wires... etc.
Replace the fuses. Test the output with a volts/ohms multi-meter, and check the fuses on whatever it is you are plugging in.
Remove the outlet panel and inspect the wires. Test their continuity. Locate the dashboard ground wires ( G107, G108 ) and make sure that they are clean and snug.
not the fuses
need to dig under the dash and check power again and find the grounds
are all the grounds inside the cab?
could anything in engine power distro box be a cause?
