OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
4.0 Oil Filter Adapter
Changed the adapter-to-block o-ring last night-had my torx t-60 bit and was ready to go......and sweating....imagine my surprise when I discovered the adapter bolt had a 5/8's standard head on it-took it off with a ratchet-cleaned everything up and was done including an oil change in about a half-hour!!! Cool.
#2
Re: 4.0 Oil Filter Adapter
I don't remember the gent's name-something-man, but he's got a website with pictures of the procedure on turning the adapter to horizontal-mentioned a t-60 bit to get the adapter off-may have been an earlier model-mine's a 1992-used a fram ph-8a oil filter for ford v-8's too. 3/4 x 16 threads and I can get my hands on the filter with no problem-I did leave it in the upright position tho...
#4
word of the wise, drop the orange can of death (fram). i gained 20psi in oil pressure switching from fram to purolator (p/n 30001). |
#5
I think I will, thanks....and it was Yuccaman's article-no disrespect to him-couldn't remember his name...I prefer motorcraft filters anyhoo....maybe even a k&n. Orange can of death, that's a hoot!!
#6
Yup, that was my site (www.yuccaman.com). It's down for a few days though while I tussle with the host but if I remember what was in there I listed info about getting the larger 1-quart filter onto the later-model (horizontal) oil filter adapter. Cool to hear that y'all had 5/8" bolts on yours - what years were they? My '96 had the T-60.
#7
i crawled under there just to check out how i'd get it off and was like, "oh sweet, an actual bolt". threw a 5/8 on it and was done in about 5 minutes. it wasn't even on there super tight like i had read (i had read about guys taping two wrenches together and trying like all hell to get it off). just a few good tugs on the open end and it was loosened up enough to get off with my fingers. |
#8
5-90 |
#9
Yuccaman, mine's a '92 and I had plenty of room to get a wrench or ratchet on it, taking care to stay clear of the starter...... If you have the machining skills, it would be a cool piece to replicate. O-rings appeared to be the same as the rest, drilled out from the engine side with 2 holes for oil flow-the '92 should get you the part you need-and my adapter would go to 90 degrees just like your article stated-I wasn't comfortable with the room I had left-great idea tho...good info, thanks.
#10
I just need to get my hands on a sample - once that's done, I'll measure & draw the thing, and start working out a CNC programme for it.
I'd not mind doing it myself for a "one-off" project - but I'll get it done if I'm going to sell any of them... 5-90 |
#11
How did you guys get a 5/8 bolt. Mine is the torx. And it took me forever to change that stupid o-ring out. Very hard to get to. Unless I was using wrong tools. LOL
#12
did mine tonight, took all of 30 minutes with giving the adapter a hot bath in dish soap. oh yeah my 90 has the 5/8 bolt too
#14
Just lucky. I think the T-60 was a ChryCo "innovation" later, AMC wouldn't make anything that difficult to work on.
I've got a couple sets of dentists' picks - I find them useful for dealing with any o-rings. Oil lines, hydraulics, paintball markers, whatever - dental picks are tops for getting under o-rings and into grooves. 5-90 |
#15
When I picked up my new "O" ring set at the dealer they asked me if I wanted a new adapter too, asked why, he told me that MANY of the adapters break when replacing the "O" rings, don't know if he was trying to make a sale or if its true.
Thread Tools | |
Display Modes | |
Air filter, oil blowback? | wildman | OEM Tech Discussion | 41 | November 20th, 2005 13:07 |
oil filter for renix | itzak | OEM Tech Discussion | 1 | January 22nd, 2004 15:04 |
leaking in area of the oil filter | gman | OEM Tech Discussion | 2 | December 8th, 2003 00:02 |
oil filter elbow bent | skog | OEM Tech Discussion | 7 | July 11th, 2003 07:25 |
OIL in the distubuter?!?!?!?!?!? | Stoney | Sierra Chapter | 5 | March 4th, 2003 05:24 |
