Power Steering Return Line ID
IIRC it's the 3/8 size, and I'm pretty sure the flare nut is something like 18mm, or some weard size not included with normal line wrench kit. I just used a regular wrench. It wasn't very tight. At least not tight enough to need a line wrench
I think it is 18mm. I just picked up a 16x18mm flare wrench.
5-90: the steering box is getting replaced so I figured I might as well replace the lines as well.
thanks to you both.
